Results 31 to 45 of 108
Thread: 13' Bullet FULL Rebuild
09-30-2019, 02:00 PM #31Screaming And Flying!
- 14,701
- 380
- 1280
- 5599
- 10934
This problem I have happened 5+ yrs years ago? It was new on the market. Lot of guys have used lots of it with no problems. I have to guess I got a bad batch. I know I mixed it properly and it seemed to get hard properly as it was easy to sand. Covered it with 545 epoxy. I have done hundreds of boats over the years and never had a problem. Contacted adtech and got told to pound sand. Just frustrating to do a 3 thousand dollar paint job and have it ruined by a supposed superior product. I can tell you, the sales guy who talked into using it got an ear full.
09-30-2019, 02:05 PM #32
Yeah that does really suck how long did it take for the blisters to appear? I tried to do a search regarding blisters and p 77 and turned up with nothing so that kind of gives me a little better feeling about using it at least it's not a widespread issue that I can tell at least. The batch that I get is only a month old so it's really brand new hopefully I don't have that issue.
09-30-2019, 02:38 PM #33Screaming And Flying!
- 14,701
- 380
- 1280
- 5599
- 10934
They didn't start appearing for about a year. They have continued to appear since and are now bad. I have opened up a few that are hidden and the adtech seems crumbly and has failed. The primer and paint is still stuck to the top surface of the adtech but the adtech has let go of the gell and glass under it. Primer is adhered well to the whole deck. Really nice Imron paint job with clear over it with a defect everywhere I used the 77. I have pics of the spots I used the 77 and they match up to where the blisters are. Hopefully can just grind out the bad areas, repair and repaint with no more spots appearing. I don't anticipate you having any problems and would not say stop and don't use it. Harden accurately and mix well....
TwzteD thanked for this post
09-30-2019, 02:48 PM #347000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
09-30-2019, 02:58 PM #35Screaming And Flying!
- 14,701
- 380
- 1280
- 5599
- 10934
It deteriorated and lost adhesion with the substrate to describe it best.
09-30-2019, 03:30 PM #367000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
TwzteD liked this post
10-01-2019, 05:45 PM #37
Love this build. You're almost done !!! Exciting! THink you'll run her at least once before the end of boating season? Oh wait - you're a florida man. Nevermind haha.
1) 1995 14' Bayliner Restoration <--Click
2) Home-Made Tunnel-Boat Project <--Click
Baja170 liked this post
10-01-2019, 05:53 PM #38
10-01-2019, 07:02 PM #39
So I have a question, I was working on the cap today for a little, the splashwell we redid , the d cell h80 seems to have darkened from a fresh sheet, is this a bad sign or nothing to worry about? It may have gotten wet or been exposed to the sun for a short. Of time it does not feel brittle or crumbly. I'm just wondering that if it got wet will it change colors? Or is it just from being glassed over? Will this hurt adhesion of fresh glass and or fairing compound? I have attached a picture of a fresh cut piece compared to the splash well that was done about four months ago. It's hard to tell if under the glass is the same color or not but the raw edge is definitely darker.
10-01-2019, 07:07 PM #40Screaming And Flying!
- 14,701
- 380
- 1280
- 5599
- 10934
It is no biggie....Sun and stuff in the air contaminate it. Use it.....
10-01-2019, 07:10 PM #41
10-02-2019, 07:59 PM #42
Oh crap - Did i not get back to you? Must have slipped down the list in my inbox. Sorry bud. I dont think i'm in the market for battery cables anymore, but don't think I did that on purpose lol.
A Xmas dunk would be great! Tell the wife n kid to leave you alone for a couple weeks!1) 1995 14' Bayliner Restoration <--Click
10-03-2019, 05:04 AM #43
No worries! Anyway ill be working on the boat today a good amount, been doing two body parts at the gym every day to free up two days for an extra few hours. I got 90% of the cap sanded, looks like there is going to be a lot of work with filling and sanding. if you look into the sun you can see about a million and a half dimples in the front, my guess due to the glass being so thin, Glad we cored it! Ill probably have to drag filler over the whole front and sand and repeat until its close then hope primer fills the rest. On a side note, i got the engine running again, after i took it apart to mod the lower unit it wasn't pumping water. I dropped the LU and reinstalled it, guess i didn't have the key way on the water pump lined up right, ran on the hose last nite for 10 mins, runs like a champ hooked up the water pressure guage to test it 2 psi at idle at trolling speed about 4, and the higher rpm the higher it goes had it to about 12 psi so works well.
10-03-2019, 06:47 AM #44Screaming And Flying!
- 14,701
- 380
- 1280
- 5599
- 10934
You will get a shoulder, traps, bicep, and forearm workout with the fairing process. I look like fn popeye after 30yrs of doing boat work....haha.
10-03-2019, 07:41 AM #45
13' Bullet 130 Rebuild & Repower
By TwzteD in forum Fiberglass and Composites DiscussionReplies: 495Last Post: 09-28-2020, 03:22 PM -
13 bullet rebuild.
By Gorilla0178 in forum Fiberglass and Composites DiscussionReplies: 0Last Post: 06-12-2018, 09:04 AM -
83 Bullet Rebuild Update
By One Oldman in forum Fiberglass and Composites DiscussionReplies: 2Last Post: 06-02-2013, 10:10 PM -
'83 19V Bullet Hull Rebuild
By One Oldman in forum Fiberglass and Composites DiscussionReplies: 2Last Post: 04-24-2013, 08:48 PM -
best place for powerhead rebuild/lower rebuild on Long Island?
By play2win in forum Technical DiscussionReplies: 2Last Post: 08-08-2011, 01:49 PM
