Results 1 to 15 of 46
Thread: 2.5 150 too cold at idle?
09-26-2019, 09:07 PM #15000 RPM
- Jul 2017
- Dothan, AL
- 109
- 12
- 30
- 11
I’m in the process of rigging a 2.5 150 and putting it on my varmint project. When running the engine, I’ve noticed that it never really gets to operating temp, 95°F - 100°F according to my infrared temp gauge, after a 15-20 minute run time. Tell tale stream is pretty much instant on start up, and does get lukewarm to the touch. Water pressure gauge is about 8 PSI and steady. Brand new impeller, and thermostats. The thermostats are aftermarket ones with the tiny bypass holes in them. Is it possible that the poppet is stuck open? I’d like to see a little more heat in this motor, not really in the mood to cold seize it. Any ideas?
09-26-2019, 10:53 PM #26000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
8 sounds high for idle, open popets should have it very low under 3.
But 8-9 is normally open pressure......
i would look for whats shooting pressure so high.
09-26-2019, 10:58 PM #35000 RPM
- Jul 2017
- Dothan, AL
- 109
- 12
- 30
- 11
09-27-2019, 03:15 AM #4Member
- Apr 2018
- Missouri
- 43
- 26
- 10
Just went through a similar situation with a 92 150XR6.
Water pressure 6psi at idle and would not increase with engine rpm. Replaced T stats with Merc brand t stats. Replaced poppet valve diaphragm and spring. Now have 2psi at idle and water pressure increases with engine rpm. At idle you should have about 2 to 3 psi, somewhere north of 1500 rpm is when the poppet valve begin to come into play and you should see somwhere around 9psi. At WOT water pressure should be a min of 12. Sorry I cant be more specific but I dont have my manual handy. Hope this helps
09-27-2019, 07:02 AM #55000 RPM
- Jul 2017
- Dothan, AL
- 109
- 12
- 30
- 11
09-27-2019, 04:07 PM #6Member
- Apr 2018
- Missouri
- 43
- 26
- 10
Here is an additional tip about your condition. Higher than nromal water pressure at idle can cause a rough idle condition also. If your engine is carbed it most likely will have a Thermal Air Valve on the odd cylinder bank. If CHT. doesn’t reach 100 deg. The valve wont open and port air to the carbs to lean the mixture out. Just an fyi for you.
09-27-2019, 04:10 PM #75000 RPM
- Jul 2017
- Dothan, AL
- 109
- 12
- 30
- 11
88/12 reaction 19 (sold)
77 hydrostream varmint 2.5
02 Caravelle interceptor 212 5.7 GI-B
09-27-2019, 04:32 PM #8Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
I would verify t-stats opening correctly in a pan of hot water. 143 deg is correct for most v-6 mercs.
09-27-2019, 04:38 PM #95000 RPM
- Jul 2017
- Dothan, AL
- 109
- 12
- 30
- 11
XstreamVking liked this post
09-27-2019, 04:42 PM #10Member
- Apr 2018
- Missouri
- 43
- 26
- 10
Only one of those ports on the TAV has a hose connected to it. The other port is open to the atmosphere. If that valve is not connected to your carbs you probably need to re-Set the idle mixture screws after replumbimg the valve to the carbs. Do you have a maintenance manual for that engine? I would highly recommend getting one if you do not.
09-27-2019, 04:43 PM #11Member
- Apr 2018
- Missouri
- 43
- 26
- 10
Good point!! On the after market T stats.
09-27-2019, 04:44 PM #125000 RPM
- Jul 2017
- Dothan, AL
- 109
- 12
- 30
- 11
09-27-2019, 04:52 PM #135000 RPM
- Jul 2017
- Dothan, AL
- 109
- 12
- 30
- 11
09-27-2019, 10:49 PM #14
I agree with poppet and double check stats. If either dont fix. its in adapter
09-27-2019, 10:50 PM #155000 RPM
- Jul 2017
- Dothan, AL
- 109
- 12
- 30
- 11
Mercury Tech: -85 200 2.4 rough idle, stumble, extreme fuel consumption, cold idle
By Roos in forum Technical DiscussionReplies: 11Last Post: 08-11-2014, 06:21 AM -
Fuel sheen on water at idle, no power to plane, tach bouncing at idle
By hevysrf in forum Technical DiscussionReplies: 11Last Post: 08-31-2010, 10:27 AM -
2.5/260 - Water Temp: How Cold Is To Cold?
By Pachanga_rick in forum Technical DiscussionReplies: 0Last Post: 07-12-2008, 06:02 PM -
idle problems when cold
By craddock in forum Technical DiscussionReplies: 4Last Post: 07-13-2007, 02:26 PM -
Cold idle smoking
By gtsmpuc in forum Technical DiscussionReplies: 1Last Post: 09-23-2001, 09:10 PM
