Results 31 to 45 of 46
  1. #31
    Jul 2004
    Connecticut
    Also, suggest you place the motor in a big ole water bucket and take a short video running. Wondering if the water pump housing might have been over torqued on installation causing a little warp.
  2. #32
    Jul 2017
    Dothan, AL
    I'm too lazy to read back, but for a EFI non smartcraft 150hp fishin motor no need to have holes in the stats. Curious if you have tried just for chits and giggles BOTH 120s and 143s?
    I doubt I’m even making enough heat to open a set of 120’s to be honest.
    The big ole bucket of water was the chattahoochee River Lol. Things aren’t much different on a water hose really.
  3. #33
    Jul 2017
    Dothan, AL
    [QUOTE=Greg G;Wondering if the water pump housing might have been over torqued on installation causing a little warp.[/QUOTE]
    would warpage cause an over pressure like that?
  4. #34
    Jul 2004
    Connecticut
    Well, I always go the big bucket at home route when the gremlins start up. Never liked the hose and muffs.
  5. #35
    Jul 2004
    Connecticut
    Good luck, let us know how you make out with this next year.
  6. #36
    Jul 2017
    Dothan, AL
    I’ve got one here, I’ll try it again and see.
  7. #37
    Jul 2017
    Dothan, AL
    Will do, I’ve got a few more boating days left here in AL. I’m hoping to get this figured out soon.
  8. #38
    Jul 2017
    Dothan, AL
    I did some more investigating this morning. I took the poppet cover off, drilled and tapped a hole to force the poppet closed. In doing that, the pressure gauge jumps up to 25-30 psi, and lugs the motor with so much pressure. This is with the hose that runs from the top of the block to the poppet valve cover, clamped off. Thermostats begin to work at this point, but the temp gauge climbs past thermostat opening temp. I feel they it would overheat quickly at this point. I pulled the foot off and put another water pump impeller and housing on. Still the same scenario. I’m pulling the powerhead and looking at the adapter the next chance I get, what do I need to look for? I do have another adapter/mid plate setup I can use, if need be.
  9. #39
    Put a new poppit bushing and retainer in the block. Glue the bushing in with weather strip adhesive and stake the retainer in with a small chisel. Water pressure at idle should be 5-10 lbs and fluctuate when the stats open and close.
  10. #40
    Jul 2017
    Dothan, AL
    Waiting on the poppet kit now, I’m not confident that it will be fixed with just that, is the thing. Im definitely going to try it. If not, I’ll be pulling the powerhead.
  11. #41
    The bushing and retainer dont come in the kit.
  12. #42
    Jul 2017
    Dothan, AL
    already ahead of that. Thanks for reminding me tho.
  13. #43
    Jul 2017
    Dothan, AL
    Poppet kit is installed and running. I’m making proper temp and pressure at idle now. Only problem I have now is as soon, and I mean instantly as rpms go over 1000, temp plummets and never comes back up while cruising. I’m going to pull the heads off and the exhaust plate off and check for blockages. If none are found, I’m gonna send it as is. If it seizes, it seizes . I’m out of options at this point. I’m ready to learn how to drive my boat. I guess this is more of a frustration post than anything lol.
  14. #44
    May 2014
    Livingston, Louisiana
    Water temp will drop to around 110 depending on inlet water temp when poppet opens. This is the reason it’s so important to allow engine to warm up good on stats and get good heat soak in sleeves before blast off, especially in colder temps.
  15. #45
    Jul 2017
    Dothan, AL
    so what I’m seeing from this point on may be normal then?
  1. Mercury Tech: -85 200 2.4 rough idle, stumble, extreme fuel consumption, cold idle
    By Roos in forum Technical Discussion
    Last Post: 08-11-2014, 06:21 AM
  2. Replies: 11
    Last Post: 08-31-2010, 10:27 AM
  3. 2.5/260 - Water Temp: How Cold Is To Cold?
    By Pachanga_rick in forum Technical Discussion
    Last Post: 07-12-2008, 06:02 PM
  4. idle problems when cold
    By craddock in forum Technical Discussion
    Last Post: 07-13-2007, 02:26 PM
  5. Cold idle smoking
    By gtsmpuc in forum Technical Discussion
    Last Post: 09-23-2001, 09:10 PM
