Results 1 to 15 of 16
    Nov 2003
    tanner park long island
    1998 Allison xr2001 RR
    1998 ALLISON RIVER RACER
    BOAT- this boat was striped and rebuild with all new parts. New okuma stringers and floor. New High Density closed cell foam Transom that is still reinforced with factory metal bracing. Transom has been cut down to accept a 15”or 12” midsection. Gel is in nice shape the black center stripe is new imron. New duel fuel system mounted on custom bracket with slosh tank fillers and relays New holley 5ld pump for carb motors and new 044 Bosch for EFI all fuel fittings are AN. Steering is a new hydraulic imco side mount ram and new telaflex 2.4 helm with blinker style trim switch and new mercury trim pump. Custom order livorsi gauges carbon fiber faces with black and yellow bezels and yellow color matched needles and trim indicator full carbon fiber race steering wheel. New original in control shifter and peddle. Digatron 53k head unit egt’s and tech . Allison bucket seats with New covers. 8”hydrodynamics jack plate and new 28 pitch hiss triton.
    MOTOR- 2001 2.5 280 ROS re-built this year with wizards 2hrs on powerhead. Midsection is a 280 smoothback cut to 12” on a custom lightened clamp with diamond tuner and lower unit is a new small shaft sport master. Cowl is a factory alien that has been hydrodiped in carbon fiber and cleared. Trailer is a new 2018 single axel aluminum ibeam. Boat is 100% turn key very low hours total of 9 rides maybe 8 hours on boat scene rebuild $17,500 turn key or hull trailer rigged 10,500 Boat is located in Long Island ny. Message, call or text Ryan at (631) 481-6127 Click image for larger version.
ID:	449624Click image for larger version.
ID:	449625Click image for larger version.
ID:	449626Click image for larger version.
ID:	449627Click image for larger version.
    allison xr2001
  2. Likes David, MarkStein, Garth91, seychellesboy liked this post
    Jul 2008
    St. Cloud MN
    that's pretty, glws!!
    Jul 2018
    Tampa, FL
    What does she run? GLWS
    Nov 2003
    I’ve only pushed it to 90 only drivin it a few times and never drove an Allison before
    allison xr2001
    Oct 2018
    Muskoka Ontario
    Msg sent
    Jun 2001
    Crosslake, MN
    Quote Originally Posted by Ryan mcc View Post
    Hell of a first Allison to play with …
    MDS
    I can't believe its for sale
  9. #8
    Nov 2003
    Bump
    allison xr2001
  10. #9
    longisland
    Don't do it
  11. #10
    Jul 2004
    Connecticut
    1998 ALLISON RIVER RACER - this boat was striped and rebuild with all new parts. New okuma stringers and floor. New High Density closed cell foam Transom that is still reinforced with factory metal bracing. Transom has been cut down to accept a 15”or 12” midsection. Gel is in nice shape the black center stripe is new imron. New duel fuel system mounted on custom bracket with slosh tank fillers and relays New holley 5ld pump for carb motors and new 044 Bosch for EFI all fuel fittings are AN. Steering is a new hydraulic imco side mount ram and new telaflex 2.4 helm with blinker style trim switch and new mercury trim pump. Custom order livorsi gauges carbon fiber faces with black and yellow bezels and yellow color matched needles and trim indicator full carbon fiber race steering wheel. New original in control shifter and peddle. Digatron 53k head unit egt’s and tech . Allison bucket seats with New covers. 8”hydrodynamics jack plate and new 28 pitch hiss triton.
    MOTOR - powerhead early 80s 2.4 225 with exhust chest opened up 5 chorme one steel standard bore. Lite wight flywheel Super clean full rebuild. Midsection is a 280 smoothback cut to 12” on a custom lightened clamp with diamond tuner and lower unit is a new small shaft sport master. Cowl is a factory alien with skirt that has been hydrodiped in carbon fiber and cleared. Trailer is a new 2018 single axel aluminum ibeam. Boat is 100% turn key very low hours total of 9 rides maybe 6 hours on boat scene rebuild.
    Asking $22,000 turn key or $15,500 minus power and Imco. Boat is located in Long Island ny. Message, call or text Ryan at (631) 481-6127
    I can't imagine you would ever find something close to this again if you regretted the sale.
  12. #11
    Nov 2003
    Ronnie rebuild probably one of, if not the nicest Allison RR around . Life consistently changes and now that I have a family I’d like have a High performance boat that all four of us can enjoy. Or no one buy the best deal on a Allison you’ll ever see and I’ll save the money to own two boats with out the wife complaining about.
    allison xr2001
  13. Likes seychellesboy liked this post
  14. #12
    Nov 2003
    Bump
    allison xr2001
  15. #13
    Aug 2006
    GA
    Nov 2003
    sold!!!!! thanks s&f!!!!
    allison xr2001
  17. #15
    longisland
    the new owner getting the deal of the century!! I hope he likes it. I have a ton of time into this thing and it shows. never see another one like this anywhere
  1. 1998 Allison XR2001 Drag $13,500
    By ecpunk in forum Hulls up to 20'
    Last Post: 08-25-2018, 06:42 PM
  2. WTB Allison xr2001
    By Esox4130 in forum Hulls up to 20'
    Last Post: 08-09-2018, 08:43 PM
  3. Looking for allison xr2001
    By yasser in forum Hulls Wanted
    Last Post: 01-01-2014, 11:45 AM
  4. Allison XR2002 v XR2001
    By woodduck in forum Technical Discussion
    Last Post: 04-25-2005, 06:40 AM
