Results 1 to 12 of 12
    Sep 2009
    Cleveland, Ohio
    Weldon Pump, Mounting bracket and Fuel pressure gauge.
    For sale is a used Weldon pump off my 260, pump was rebuilt in 2012 by Weldon in Walton Hills Ohio. No issues has an aluminum mounting bracket to mount to a wall.
    I also have a newer (used 5 seasons) white auto meter gauge and sender for an additional $50 if you buy the pump. Will add pictures of gauge later but it is in excellent condition.
    Asking $350 for the pump, $400 with the gauge or best offer would like to sell quick.Click image for larger version.
ID:	449309Click image for larger version.
    1986 cougar mtr 21
    2003 supra launch ssv
  2. Likes stoker2001 liked this post
    Sep 2009
    Cleveland, Ohio
ID:	450775Gauge and sender included for $350 shipped inside us
    1986 cougar mtr 21
    Sep 2009
    Cleveland, Ohio
    $225 shipped with gauge and sender
    1986 cougar mtr 21
    Sep 2009
    Cleveland, Ohio
    Bump $225 Shipped pump, bracket, gauge and sender
    1986 cougar mtr 21
    Mar 2002
    Rockford, MI
    Will this pump handle the 260 EFI with 56lb Regulator (A6 or A63 box)?
    "The Flying Clamato"
    ...This ain't no Party, This ain't no Disco, this ain't no foolin around..."Talking Heads - Life During Wartime"
    The G-Train has left the station.
    Sep 2009
    Cleveland, Ohio
    Quote Originally Posted by G-Train View Post
    Yes sir this was mercury racing pump of choice
    1986 cougar mtr 21
    Mar 2002
    Rockford, MI
    OK, I understand that this Pump 2001-A was originally used for the 2.0l and the early 2.5l's. Then they changes to a different pump for the 56lb regulator.
    Did they upgrade it when you had it rebuilt for the 56lb regulator? Just need to make sure.
    Thanks
  9. #8
    Sep 2009
    Cleveland, Ohio
    Not sure I will try to get you an answer
    1986 cougar mtr 21
  10. #9
    Sep 2009
    Cleveland, Ohio
    Weldon pump said they use that same pump in airplanes, it has been used on 300 drag motors for years with no issues
    1986 cougar mtr 21
  11. Likes evinrudejohnson liked this post
    Mar 2002
    Rockford, MI
    OK, you will probably hear from someone I am referring to this pump soon.
    Thanks
    Nov 2010
    Il
    Sent pm
  14. #12
    Jun 2012
    Indiana
    Older style Weldon pump came with EFI bridgeports back in the day. I have that exact same pump and I used it on my 2.5 260 but I was running 39 lbs. I think this pump would be fine.
