Results 31 to 45 of 56
09-22-2019, 05:39 PM #315000 RPM
- Nov 2013
- Florida
- 121
- 15
If I had a bad coil or any ignition problem outside of a timing concern a weak spark would generally cause a noticeably different looking spark plug. No?
09-23-2019, 09:44 AM #32
Yes and no ..
The early model ignitions could have a bad CDM and it would pick on a different hole.
Vnemous texted me the pages with all the early model specs ... a couple years ago since my service manual doesn't cover that far back .
I'll find the info , or text him to see if he will post it here . It's all ohm meter stuff .
Bobby will have it too , I'll pester him as well ..
Chaz = thinkin, it should become a sticky
09-23-2019, 09:52 AM #33
That was easy ... right where I left it .. downloads ...
RSWORDS liked this post
09-23-2019, 09:59 AM #346000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
Possible clogged exhaust on one not letting enough exhaust to that prop to slip it?
09-23-2019, 11:05 AM #356000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Tach could be off as well and nothing wrong with the engine. Try confirming tach signals, regulator rectifier. Battery hookup if changed can also be crossed up.
09-23-2019, 01:19 PM #365000 RPM
- Nov 2013
- Florida
- 121
- 15
The engine in question builds rpms at a slower rate, even if the tach was off it’s still obvious that the port engine is weaker to get going.
reeds are on the way. I’ll do as much checking as I have time for but I’m a busy guy and may just throw the reeds in and see where I’m at. At the very least I will check all the coils and timing. Thanks again for all the input, I’m confident that I can solve this with all of the information I’ve been given here.
09-23-2019, 05:29 PM #375000 RPM
- Nov 2013
- Florida
- 121
- 15
Ok so the reeds are all in excellent condition aside from one thing. I noticed the rubber coating to be coming apart on the top reed block on the port or problem outboard. Doubtful that is causing anything but I’ll het a used unit before I do the reeds anyway.
On to the electrical checks tomorw and timing after reeds installed.
09-23-2019, 05:47 PM #38
You can send them out and have the rubber coating taken off and they will seal better.. if they are cracking that bad.
Can't tell from pics..
If the cracking isn't to bad when you lap them it should take care of it.. did you get stuffers too or no?
MichaelLETS GO BRANDON.... LETS GO BRANDON
'84 Checkmate Convincor
09-23-2019, 06:09 PM #395000 RPM
- Nov 2013
- Florida
- 121
- 15
I cheeped out on the stuffers. I honestly cant see putting the reeds 65 thousandths closer in making a noticeable difference in my hum drum application. you could loose the gasket and put the reed plate on with rtv and get them 30 or 40 thousandths deeper, why does nobody just do that?
upon closer inspection one of the reeds was bent slightly and id bet that caused a flutter bad enough to beat the rubber coating off.
09-23-2019, 06:16 PM #40
Well like you said your a bit over powered right now till you get them converted to 25s so.. was just curious and if you did how much if a difference there was..
All it takes is one bad Reed and that could be all the problem the 1000 rpm difference the sneezing.
Just make sure you lap them really wellLETS GO BRANDON.... LETS GO BRANDON
09-23-2019, 07:45 PM #415000 RPM
- Nov 2013
- Florida
- 121
- 15
I have been playing with, porting, and modifying 2 strokes in anything from dirt bikes, atv, waverunners, stand up skis, mopeds, even snowmobile engines for many years and i have never heard of lapping a reed valve lol. please explain, you marine guys are a different breed of 2 stroke guys.
and i am certain that small defect in the reeds will have caused my sneeze. Im not positive it would cause the low power but we will see soon.
09-23-2019, 07:52 PM #425000 RPM
- Nov 2013
- Florida
- 121
- 15
I completely forgot to ask when i called Carson marine service today, how much does it run and is it worth having the injectors cleaned. is there any adjustments they make to even them out or is it just a cleaning.
09-23-2019, 07:56 PM #43
Oh you don't lap the Reeds you lap the cages it's truing them by sanding them on a flat surface metal or glass etc
With sand paper then can use a compound..
So they are nice and flat and clean so they seal really wellLETS GO BRANDON.... LETS GO BRANDON
09-23-2019, 07:57 PM #44
$25-35 an injector and i would definitely do it on a regular basis
09-23-2019, 08:04 PM #45
And yes you do it to the rubber..
But if rubber is getting bad cracking etc you can send them out and have them remove the rubber..
I've done it with a chemical that dissolves the rubber then lapped them..LETS GO BRANDON.... LETS GO BRANDON
Common problems Optimax 225s and 250s?
By at100plus in forum Technical DiscussionReplies: 5Last Post: 11-11-2015, 07:03 AM -
verado 250s not reaching max rpms
By donzi 28 in forum Technical DiscussionReplies: 9Last Post: 01-06-2011, 08:39 PM -
mercury 250s EFI on 27 feet Catamaran speedboat
By LA7LO7 in forum Technical DiscussionReplies: 0Last Post: 06-17-2007, 04:28 PM -
Twin 250s run Rich......FIXED
By ranger250Center in forum Technical DiscussionReplies: 0Last Post: 07-30-2004, 04:38 PM -
Twin 250s run Rich
By ranger250Center in forum Technical DiscussionReplies: 4Last Post: 07-30-2004, 04:36 PM
