Results 16 to 30 of 56
09-22-2019, 11:53 AM #165000 RPM
- Nov 2013
- Florida
- 121
- 15
great input guys, ill be looking into the reeds before the motor has to eat one. looks like some reeds and check the timing before my next trip out and ill see where im at.
09-22-2019, 11:54 AM #175000 RPM
- Nov 2013
- Florida
- 121
- 15
i do think a spun hub would be more obvious, its got the square plastic ones not the press in rubber style.
09-22-2019, 12:32 PM #18
Oh so is the 1000 RPM thing recent or no?
If reeds have been like that RPM could be something else.
I would still check the props I got two that I thought were matched and after looking they were just a hair different and made the difference on takeoff like that... Although it didn't even out after planning off.. but the holes could make the difference..
And yea things going thru the motor can make a mess..
Worse than a Reed
a Reed stop went thru one of mine .
That's why I went with what I did..
'84 Checkmate Convincor
09-22-2019, 01:04 PM #195000 RPM
- Nov 2013
- Florida
- 121
- 15
you know I'm about to get "forumed" on these reeds. you know when you start reading too much on the forum and all the sudden you absolutely have to do, buy, or check/rebuild something lol. was that broken reed stop corrosion related
so should i go for the 6 pedal or 3 pedal carson reeds. do you recommend any additional parts while im in there.
09-22-2019, 01:14 PM #20
Not corrosion related but they were 30 years old and the older style the newer ones the gap between them doesnt go down as far..and has more metal in there ..
But I didn't want to use stops so I used boyesen
And motors were getting spun higher and I wasn't gentle on the boat either.
Stick with the 6 petal.. BUT let someone who has them and uses them give you advice on that..
Any thing else in there ? Stuffers since you will have it openLast edited by mrichartz; 09-22-2019 at 01:16 PM.
09-22-2019, 01:29 PM #21
And forumed keep reading or post what can I do to my motor.. then as you know you in for it.. lol
09-22-2019, 01:35 PM #22
Although twin 250 on a 23' center console..but guess heavy now... but what kind of speeds?
09-22-2019, 02:25 PM #235000 RPM
- Nov 2013
- Florida
- 121
- 15
It starts to get tough to handle at about 60mph, plenty of throttle left. It cruises 45mph at around 4200 rpm to give you an idea. It performs pretty well but the motors are too deep in the water with the 30” shafts even on the highest mounting point is should still be a few inches higher or convert to 25”.
It’s not heavy it just used to weigh nothing... no stringers at all in its original design and all balsa core keel to rub rail, pretty crazy. It’s a 1971 seabird.
09-22-2019, 02:30 PM #245000 RPM
- Nov 2013
- Florida
- 121
- 15
09-22-2019, 02:32 PM #25
Well I guess that would be next huh.. convert to 25"?
Oh yea those are really deep especially with that setback.
Oh you made it sound heavy..
Nice looking boatLETS GO BRANDON.... LETS GO BRANDON
09-22-2019, 02:40 PM #265000 RPM
- Nov 2013
- Florida
- 121
- 15
Yea I’d like to convert them, I’m putting off my impellers because I’d like to put them back together as 25”. Is there anyone who can chop and weld the shafts without going through a lower unit rebuild. I can handle the shift shafts myself, I can weld stainless but I have no tooling to true a driveshaft.
09-22-2019, 02:51 PM #27
I would definitely leave that to someone who does it..
Chris Carson does it..
He cuts the shaft then cuts the shaft splines in while it in the lower unit so no need to take apart
And that way no welds
You don't have adapters right ?Last edited by mrichartz; 09-22-2019 at 02:57 PM.
09-22-2019, 04:38 PM #28
OK ... second guess is the weak side is a member of the "black plug tribe" and has a bad bobbin on the stator or a bad (coil) CDM .
Let me know when you have run a full diagnostics test, and I can take the blindfold off ..
09-22-2019, 04:40 PM #295000 RPM
- Nov 2013
- Florida
- 121
- 15
I’ll order the reeds and check the timing tomorrow. I’ll post the results
09-22-2019, 04:44 PM #30
Put the light on all 12 leads .. make sure that none look erratic ....
Common problems Optimax 225s and 250s?
By at100plus in forum Technical DiscussionReplies: 5Last Post: 11-11-2015, 07:03 AM -
verado 250s not reaching max rpms
By donzi 28 in forum Technical DiscussionReplies: 9Last Post: 01-06-2011, 08:39 PM -
mercury 250s EFI on 27 feet Catamaran speedboat
By LA7LO7 in forum Technical DiscussionReplies: 0Last Post: 06-17-2007, 04:28 PM -
Twin 250s run Rich......FIXED
By ranger250Center in forum Technical DiscussionReplies: 0Last Post: 07-30-2004, 04:38 PM -
Twin 250s run Rich
By ranger250Center in forum Technical DiscussionReplies: 4Last Post: 07-30-2004, 04:36 PM
