Results 16 to 21 of 21
09-19-2019, 03:00 PM #16
X2 on James Perry my mid '90s Evinrude Loopers he did the porting, pistons milled to match the finger porting, resleeved all 12(put them in opposite to block the idle reliefs) and machining on my motors and his work is awesome!!.. (actually my motors are 80s,90s mix of parts)
BUT he's right your going to have alot of money into that work if you go that route.. should be able to find a bolt on powerheadLast edited by mrichartz; 09-19-2019 at 03:25 PM.
'84 Checkmate Convincor
09-19-2019, 05:43 PM #17
John got 200 with bolt on stuff, no porting.
09-19-2019, 05:46 PM #18
Do not b afraid of putting a 200 on a "175" rated hull. My 18.5 bass boat is rated 175 , I have mild build 200 and the weight is no difference between the 2 , and really ain't hard to drive round 80 , boat wont sit no different n water , only thing would b insurance issues , the 150 xri is great motor , I'm like bullet123 , carb guy ,, but do know they run gud , only thing I worry about on efi is , when is to much compression for the stock ecu or whatever it is ? But compression and a couple bolt ons will help
09-19-2019, 06:09 PM #19Member
- Aug 2016
- Minnesota
- 84
Is there a place online to find those old articles?
I googled and found a few but not the one you are referencing.1995 ProCraft SuperPro 180 / Mercury 150 XRI
1997 ProCraft SuperPro 200 / Mercury 225 3L
09-19-2019, 07:15 PM #20
Not sure someplace I have the magazines.
09-19-2019, 07:26 PM #21
The bolt on’s will help. From my experience without porting changes, most noticeable gains will be down low and mid range acceleration. Top end speeds gains are usually smaller. If your looking to be quicker then keep what ya got with bolt on’s. Looking for sizable mph gains either get with someone to port yours or get one of the higher hp blocks.
Merc 2.5 liked this post
Mercury Performance 3.0
By gonegamblertx in forum Outboard EnginesReplies: 5Last Post: 01-30-2017, 08:52 PM -
Mercury Hi Performance 15 in Mid
By chevrolet 55 in forum Misc. Parts and AccessoriesReplies: 1Last Post: 08-03-2016, 04:28 AM
