Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 16 to 30 of 65
Thread: 2.4 intake
    Sep 2017
    Ashland city tn
    Quote Originally Posted by gambler ss View Post
    I ported the exhaust ports to match the bobs performance tuner- it’s a stock 2.4 rebuilt power head, installed boysen power reeds , solid motor mounts , and put a bobs low water pick up on.
    I haven’t even turned it over yet just dropped the power head on today so I don’t know compression.
    The guy helped me take it apart 2 years ago isn’t around and I’m not a mechanic so I’m struggling with the assembly!
    Im missing parts for the shift linkage on the motor!!
    do you know where I could find the missing shift linkage ?
    Attachment 449158
    Did u find ur linkage stuff. I forgot to look yest.
    Mrzip. Those carbs he has r good ones. same ones on my 2.5 but I'm sure u no that already
  2. #17
    Jul 2018
    hartford WI
    Yes I use a file on a sawsal it worked great
  3. #18
    Jul 2018
    hartford WI
    I didn’t find the linkage parts
    might be able to mc giver it put would rather us the correct parts
  4. #19
    Jul 2018
    hartford WI
    Thanks but I slotted the holes on the one I have
  5. #20
    Pekin, IL
    I found a couple intakes but see you modified yours. If you need anything else let me know as I have a bunch of stuff I need gone.
    Rock
    Team Junk
  6. Thanks gambler ss thanked for this post
  7. #21
    Jul 2018
    hartford WI
    Thanks I’m sure I will
    boy I-Wish I would have gone on here before I started this project! LOL
  8. #22
    Jul 2018
    hartford WI
    Another problem
    I had to replace my trim tilt pump motor with new 2 wire motor with relays
    wired it up the way it specifies and it only goes up
    if I switch green and blue wire it will go down!!
    Have any ideas
  9. #23
    Jul 2018
    hartford WI
    The green wire relay or down relay clicks but won’t work
  10. #24
    Sep 2017
    Ashland city tn
    Bad relay
  11. #25
    Jul 2018
    hartford WI
    Also are these small ports necessary or can I plug them somehow Click image for larger version.
    Attached Thumbnails Attached Thumbnails 4EC958A7-46EC-4BC9-A230-CF66F6F40DAE.jpg   31C7BFA0-5460-4D77-81D2-72E0B8D15B46.jpg
  12. #26
    Jul 2018
    hartford WI
    Sorry the picture are upside down
    should I Remove the tee and just run a hose from the top to the bottom and out the Cowling or does it need to go somewhere ??
    Thanks
  13. #27
    Apr 2017
    pa
    5 Post(s)
    Looks like bleed line check valve . Do you have a manual?
  14. #28
    Pekin, IL
    Do not cap ports in above pic. Those should have lines going to the block oiling the center mains.
    Rock
    Team Junk
  15. Likes bullet123 liked this post
  16. #29
    Pekin, IL
    The line with the tee goes to the adapter plate.
    Rock
    Team Junk
  17. #30
    Sep 2017
    Ashland city tn
    Like stated above , those r bleed lines and very important, hose with tee for coolin ,important also hook em back up,, I prob have pdf of a manual i can send. It b ur best friend
  1. intake
    By genea01 in forum Technical Discussion
    Last Post: 09-14-2009, 09:13 PM
