Results 16 to 30 of 65
Thread: 2.4 intake
09-20-2019, 07:22 AM #16
09-20-2019, 07:29 AM #17Member
- Jul 2018
- hartford WI
- 39
- 7
Yes I use a file on a sawsal it worked great
09-20-2019, 07:36 AM #18Member
- Jul 2018
- hartford WI
- 39
- 7
I didn’t find the linkage parts
might be able to mc giver it put would rather us the correct parts
09-20-2019, 07:53 AM #19Member
- Jul 2018
- hartford WI
- 39
- 7
Thanks but I slotted the holes on the one I have
09-20-2019, 02:03 PM #20
I found a couple intakes but see you modified yours. If you need anything else let me know as I have a bunch of stuff I need gone.
RockTeam Junk
gambler ss thanked for this post
09-22-2019, 07:53 AM #21Member
- Jul 2018
- hartford WI
- 39
- 7
Thanks I’m sure I will
boy I-Wish I would have gone on here before I started this project! LOL
09-22-2019, 05:17 PM #22Member
- Jul 2018
- hartford WI
- 39
- 7
Another problem
I had to replace my trim tilt pump motor with new 2 wire motor with relays
wired it up the way it specifies and it only goes up
if I switch green and blue wire it will go down!!
Have any ideas
09-22-2019, 05:22 PM #23Member
- Jul 2018
- hartford WI
- 39
- 7
The green wire relay or down relay clicks but won’t work
09-22-2019, 05:26 PM #24
Bad relay
09-23-2019, 12:52 AM #25Member
- Jul 2018
- hartford WI
- 39
- 7
09-23-2019, 01:00 AM #26Member
- Jul 2018
- hartford WI
- 39
- 7
Sorry the picture are upside down
should I Remove the tee and just run a hose from the top to the bottom and out the Cowling or does it need to go somewhere ??
Thanks
09-23-2019, 06:09 AM #27
Looks like bleed line check valve . Do you have a manual?
09-23-2019, 07:02 AM #28
Do not cap ports in above pic. Those should have lines going to the block oiling the center mains.
RockTeam Junk
bullet123 liked this post
09-23-2019, 07:08 AM #29
The line with the tee goes to the adapter plate.
RockTeam Junk
09-23-2019, 07:11 AM #30
Like stated above , those r bleed lines and very important, hose with tee for coolin ,important also hook em back up,, I prob have pdf of a manual i can send. It b ur best friend
intake
By genea01 in forum Technical DiscussionReplies: 6Last Post: 09-14-2009, 09:13 PM
