Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
    Jul 2011
    Gloucester, VA
    Quote Originally Posted by KIRCHNER View Post
    Those are some clean hands, for lower unit service LOL. GOOD you found that impeller, for sure. i guess im lucky, getting a little lazy too. just sold my suzki dfi 175 4stroke 2012, original wp. maybe someday ill regret it. or find a mechanic i can trust working on my stuff.
    I wash my hands probably 10 times a day. Nothing worse then a customer getting a boat back with greesy fingerprints all over it.
  2. #17
    Jul 2011
    Gloucester, VA
    Kirchy, these young buck's are "factory trained technicians" , not mechanics ..
    And they all wear disposable rubber gloves ..
    It usta be customers ain't allowed in the work area ...
    Now they teach em in school , when the customer wearin a suit and tie wanders around back , don't shake his hand and pat him on the back while yur hands is full of hypoid gear oil ...
    No gloves here. Just lots of soap. Lol and I don't let anyone in my shop unless they need to be. Lol
    You get the package?
  3. #18
    Jul 2011
    Gloucester, VA
    Not too long ago I had one of "Mercurys Finest" send me a 305 two barrel Rochester. "We don't work on those"........traslation..."We don't know how to work on those".
    I think we are one of the few shops that still works on mercruiser around here let alone rebuilds carbs.
  4. #19
    Quote Originally Posted by RSWORDS View Post
    Not yet ... maybe today
  5. Likes RSWORDS liked this post
  6. #20
    Impeller every year. cheap and easy to do. grease the spline. never had any of my driveshaft's get welded in.
    then we get Mr stupid...... "mine never been out in 10 years would you change mine for me" ....me.. not until you loosen all the bolts and drop the leg 1 inch.
    then ill do it..
    I am not going to sit around for 2 or 3 days trying to un-seize a driveshaft due to stupidity, ignorance and greed,....
    even if the blades dont rot the impeller takes on a set... plus gives you something to do on a rainy day..
  7. Likes bullet123 liked this post
  8. #21
    Calgary, Alberta
    At the J/E dealership I used to work at people who wouldn’t proactively change WP impellers were “good for business” ha ha. Oh it was a 1.5 hr job before .....well now you need a head gasket, etc etc.
    On the stuck driveshafts: we nearly always were working on saltwater engines so this was pretty common, especially on the smaller engines. We had a custom puller that would pop out a shaft in about 10 minutes, that made us lots of money too. Spending 3 days on a stuck shaft is a no-go in a production environment.
    Matt
  9. #22
    Gothenburg, Sweden
    If you run fast enough, you don’t need an impeller.
  10. Likes eli liked this post
  1. Replies: 15
    Last Post: 01-14-2015, 03:44 PM
  2. Mercury Tech: Changing water pump impeller on Merc 200 2.5
    By rgsauger in forum Technical Discussion
    Last Post: 05-25-2012, 07:39 AM
  3. changing water pump
    By 81hydrostream in forum Technical Discussion
    Last Post: 03-20-2010, 11:01 AM
  4. Proceedure for changing water pump impeller
    By Baja 252 in forum Technical Discussion
    Last Post: 11-12-2007, 01:10 AM
  5. Changing water pump - how do I get the impeller off?
    By OldMerc in forum Technical Discussion
    Last Post: 08-13-2004, 09:28 PM
