Results 16 to 22 of 22
09-19-2019, 07:19 AM #166000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
09-19-2019, 07:20 AM #176000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
09-19-2019, 07:21 AM #186000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
09-19-2019, 08:57 AM #19
RSWORDS liked this post
09-19-2019, 09:57 AM #20
Impeller every year. cheap and easy to do. grease the spline. never had any of my driveshaft's get welded in.
then we get Mr stupid...... "mine never been out in 10 years would you change mine for me" ....me.. not until you loosen all the bolts and drop the leg 1 inch.
then ill do it..
I am not going to sit around for 2 or 3 days trying to un-seize a driveshaft due to stupidity, ignorance and greed,....
even if the blades dont rot the impeller takes on a set... plus gives you something to do on a rainy day..
bullet123 liked this post
09-20-2019, 09:15 AM #216000 RPM
- Calgary, Alberta
- 1,123
- 21
- 58
- 341
- 174
At the J/E dealership I used to work at people who wouldn’t proactively change WP impellers were “good for business” ha ha. Oh it was a 1.5 hr job before .....well now you need a head gasket, etc etc.
On the stuck driveshafts: we nearly always were working on saltwater engines so this was pretty common, especially on the smaller engines. We had a custom puller that would pop out a shaft in about 10 minutes, that made us lots of money too. Spending 3 days on a stuck shaft is a no-go in a production environment.
Matt
09-20-2019, 01:21 PM #22
If you run fast enough, you don’t need an impeller.
eli liked this post
Cant Line Up Shifter Splines After Changing Water Pump 82 Black Max 200
By maineidyl in forum Technical DiscussionReplies: 15Last Post: 01-14-2015, 03:44 PM -
Mercury Tech: Changing water pump impeller on Merc 200 2.5
By rgsauger in forum Technical DiscussionReplies: 6Last Post: 05-25-2012, 07:39 AM -
changing water pump
By 81hydrostream in forum Technical DiscussionReplies: 6Last Post: 03-20-2010, 11:01 AM -
Proceedure for changing water pump impeller
By Baja 252 in forum Technical DiscussionReplies: 2Last Post: 11-12-2007, 01:10 AM -
Changing water pump - how do I get the impeller off?
By OldMerc in forum Technical DiscussionReplies: 14Last Post: 08-13-2004, 09:28 PM
