Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
    Folsom, Cal
    Quote Originally Posted by mistah_max View Post
    thanks for everybodys response and suggestions but i found what was wrong
    ...lol cant believe it but hey, it is what it is.
    so i took off the throttle body to have a better look at the reed valves with a camera...looked at the bottom and there it was...the stupid rubber sealing ring that goes on the throttle body had fallen at the bottom of the plenum matching perfectly the bottom so when i first looked in the plenum earlier i never saw it....lol i just laughed! but at the same time i was thinking this couldnt just be it... so back to the ramp and back it in. let it warm up and tried to take off.. success! couldnt believe it! there a soight hesitation of maybe a second before spooling up but its a trough hub prop. seems to runs great now...mannn...
    ill still get the injector flowed and ill do reeds also. luckly no further damage was done form that thong being down there!
    SO,the stringy oring was caught between petals and cages keeping reeds from sealing on just the bottom cage?
    "Whacker Smacker" #561 IHBA M/E div1 2007& 2006 first looser champion
    2007 Sportsmen Driver of the Year
  2. #17
    Jul 2011
    Gloucester, VA
    i read about those. i dont quite understand what they do though..
    Same as milling the front. Easy to Install.
  3. #18
    Jul 2009
    gatineau qc, canada
    Quote Originally Posted by stoker2001 View Post
ID:	449305 this ring that seals the throttle body on the cowl.
    1998 charger stv. 225 promax. -sold-
    1993 22 talon. 2016 yamaha 200 SHO, nizpro tuned
  4. #19
    You can buy an aluminum billet top ring from Mad EFI so that doesn't happen again. Its amazing how much a thru hub loads the motor down low. The direct inject (XS) motors make more torque down low and are not so fickle on propeller choice.
    Glad you got it solved -
    By sinking the reed block into the crankcase, you decrease the crankcase area by the volume the dressed reed block displaces. I would estimate between 15~20cc .
    While at the same time increasing the plenum volume 4.5cc ..
    Rubber coating was a quick and easy way to finish the blocks without machining and polishing a metal surface ...
    Unfortunately , it tends to look like the desert floor after a while ..
    And seals like ....
  6. Thanks mistah_max thanked for this post
  7. #21
    Jul 2009
    gatineau qc, canada
    Quote Originally Posted by JPEROG View Post
    initial test after i found the rubber ring was done alone with a 38 promax. takeoff wasnt perfect but it wasnt bad either.
    But, the next day i went for a ride with the gf and i could barely get on plane with the 30 bravo 1 with 4 holes in it. took 4-5 seconds to pull up rpms and start slipping.. cant believe how much of a dog it is compared to a xs. once on plane it ran good. actually i ran my best speed of 93mph with a passenger with more left. but it definitely needs more holes to help on takeoff. and i need to find a 15in overhub prop for next year i think..
  8. #22
    I typically run 4 blade over hubs on my stuff. The 300R is the solution. I guess we all need to wait until they start to come out on the used market.
  9. Likes mistah_max liked this post
  1. 1990 225 evenrude ocean pro wont get on plane
    By HaulNbass in forum Technical Discussion
    Last Post: 07-21-2018, 05:45 PM
  2. black max wont power up/ plane out
    By stivov1 in forum Technical Discussion
    Last Post: 06-28-2017, 06:40 AM
  3. Boat wont plane...
    By crankn101 in forum Technical Discussion
    Last Post: 08-26-2013, 09:26 AM
  4. Mercury Tech: 95 mariner 200 efi wont plane
    By Old Skeeter 2 in forum Technical Discussion
    Last Post: 06-18-2013, 11:36 PM
  5. jet40 wont plane
    By eightpt in forum Technical Discussion
    Last Post: 07-30-2004, 09:36 PM
