Results 1 to 5 of 5
    Folsom, Cal
    twin Optis 06 250XS port motor running too rich?
    trying to help a friend,port motor seems too lag.did comp test all at 125.ALL sparkPlugs are charcoal black and noticed air pump has external oil leak coming from shaft,but rotates super smooth and no play either direction by hand with belt off.did not check air/fuel pressures as my automotive style EFI gauges would not adapt..I need part# for Mercury or snap-on dual gauge liquid filled please and can air pump be resealed?thanks
    "Whacker Smacker" #561 IHBA M/E div1 2007& 2006 first looser champion
    2007 Sportsmen Driver of the Year
    Feb 2014
    Missouri
    Never tried to rebuild one, merc shows a diagram with parts though,
    rich is almost impossible on an opti
    they burn black with high octane non ethanol.
    In this heat heat it’s more likely a heat soaked iat sensor,
    mine wouldn’ Even climb on plane yesterday when I idled to Long and ran her up to 138 for a few minutes doing dock work. 101 heat index plus temp sensor showed water 138 iat had to be reading 140+.
    Check your tps, or even swap the tps's and see if prob follows.
    Folsom, Cal
    I understand mercury doesn't offer parts for the discontinued unpainted single bearing pumps,but heard I might be able to source aftermarket for bearing and seal like timkin or CR for seal..somebody surely has done this?
    Folsom, Cal
    great idea thanks
  1. 23' Eliminator Twin 250 Optis
    By noli in forum Ebay Listings and Other Internet Listings
    Last Post: 10-04-2015, 08:55 AM
  2. 2.4 200 running rich...
    By cocacola in forum Technical Discussion
    Last Post: 07-15-2015, 02:14 PM
  3. Pro-Max running rich???
    By Deacon in forum Technical Discussion
    Last Post: 03-28-2011, 03:11 PM
  4. running too rich....
    Last Post: 07-16-2008, 10:38 AM
  5. New Motor Decals for my twin Merc Optis
    By shooter810 in forum Appearance Mods
    Last Post: 03-03-2006, 11:09 AM
