Results 1 to 1 of 1
Thread: water pump
09-14-2019, 05:20 PM #1Member
- Sep 2019
- madison wisconsin
- 31
- 10
water pump
so 1988 mercury 90 hp 3 cylinder i dont know much history on this engine so i first got it running. had water in fuel
. today installed a new water pump thermostat and poppet spring. the pump plate and cover were in really good shape so i did not replace the bottom plate or the top i did install a new impeller and tube seal. I started motor and i have water right away from the tell tale and seems to be pumping and plenty of water at hose. At the lower unit shift shaft i am getting water pumping out here and the hole directly behind it . I watched a couple of vids on youtube and couldnt really tell if this is normal not does the manual say anything.
Changed water pump for my 1st time, no water flow. Most likely thing I got wrong?
By Bumblebeeman in forum Technical DiscussionReplies: 54Last Post: 09-23-2019, 11:00 AM -
Mercury Tech: 89 200HP Mariner Low Water Pressure - water pump and hoses flow fine
By tristanlee85 in forum Technical DiscussionReplies: 25Last Post: 07-02-2018, 10:59 PM -
Mercury Tech: mercury 2.4l high water pressure after I installed water pump kit.
By sasquitch in forum Technical DiscussionReplies: 23Last Post: 07-31-2010, 09:16 PM
