Results 1 to 11 of 11
    Nov 2012
    Bonita Springs Florida
    1999 OX66 Hydro tec Kits
    It has been a while since I have been here. I have two 1999 OX66 225 engines. One has actually been rebuilt by Hydro tec. I am looking for more power for my boat. I have been looking at their "Phase kits" but there is very little information on actual gains. Both of my motors run to 5500 RPM with no issue on a tuned 19" SWS prop. Compression is 120 +/- a pound on all 12 cylinders. I think my blocks are good for an upgrade. My question, has anyone used their kits on OX66s on a heavy boat and what gains did you get? Did you lose something on the bottom to gain top? Higher octane fuel requirements? Drawbacks?
    Any info is helpful
    Jul 2004
    Connecticut
    How heavy a boat? On the correct hulls the phase kits have been proven again and again. What type of boat do you have? How long are your mids? Can you get high test fuel on the water where you boat?
    Nov 2012
    Its a 2870 Pursuit CC. On the trailer full of fuel and water I am about 8700 lbs on the cat scale. I can get Rec 90 on the water but can have anything delivered to the boat, or I can caddie. Octane is not an issue unless I need AV gas. My Motors are 25 inch.
    Jul 2004
    Connecticut
    Quote Originally Posted by EMC 2870 View Post
    Wrong application. Go find yourself a pair of clean HPDI 300's and upgrade that way. 25" HPDI's are everywhere and burn 87. Good luck.
    Sep 2017
    Ashland city tn
    Ya 300 would b better route if funding available, the ox66 , they have built sum mean ones round here. Issue with urs is all the weight , if u do mods and raise comp ,, u take bigger chance of detonation and such ,, can it b done yes it can , but if u do go the build route , make sure ur spinning the motas least 6k rpm. When u lug em with lots weight and over sized prop it will kill em relatively quick
    Nov 2012
    Understood. Thank you for the advice. Right now it will run 52 at 5500 rpm loaded or unloaded with a set of nicely worked 19" SWS props. I could probably get some more speed with 21s but I really like the way she jumps out of the water.
    Sep 2017
    Ashland city tn
    What I'm saying is ur lugging the motors a little now , if u had a 18 or work ur 19s to 18 u will get the rpm u need and wont lose speed and take off b even better
  8. Likes EMC 2870 liked this post
  9. #8
    Nov 2012
    Quote Originally Posted by Merc 2.5 View Post
    As currently set up, 5500 is max RPM per the manual. I thought because I can get to it fully loaded with 1400 lbs of fuel, 200 lbs of ice and four fat dudes, I am propped Ok. Low fuel no ice and just me, I stay at 5500. I dont know if I have a rev limiter, but power drops off at 5600 no matter the load.
    So your saying I can get over 5500 and be ok the way its set up now?
  10. #9
    Sep 2017
    Ashland city tn
    Well maybe I'm just way off on this but I thought the ox66 could turn sum better rpm. Manual for 200 2.5 merc is 5500 -5800 I believe , but they live a gud life at 7k ,, need someone with that experience to chime in for ur mota , u sure it not 5500-5800 or 6000rpm. Should b a low and high range , by manual meaning no lower and no higher than 2 posted #s
  11. Likes EMC 2870 liked this post
    Nov 2012
    Manual says 5200-5500
    I am sure it could spin more, but it pulls like hell to 5500 and drops off after that.
    I am more of a car guy. I think props like the converter (prop slip) Transmission and rear gear. I have the prop set up to bite at 3000 rpm (like a high stall converter) and to get to max rated RPM fully loaded. Its like a car with a 3000 stall converter 4.10 rear end, Hits max rpm while racing, but rev limiter keeps it in check when playing around.
    Nov 2012
    Before I had my props tuned, the would bite at about 2200 rmps which really really hurt my hole shot. Adding ventilation really woke up the hole shot. The 400 rpm difference doesn't seem like a lot but really put it into the power band of the motors.
  1. Which controls for 1999 225 yammie 225 OX66? 703 or 704
    By CircleHook in forum Technical Discussion
    Last Post: 12-20-2016, 04:39 PM
  2. 2- 1999 Yamaha OX66 250 hp outboards
    By steve painter in forum Outboard Engines
    Last Post: 10-26-2016, 07:02 PM
  3. 1999 Yamaha 250 OX66
    By dreamerdfl in forum Outboard Engines
    Last Post: 01-12-2015, 08:06 AM
  4. Yamaha 1999 OX66 250
    Last Post: 12-16-2014, 12:22 PM
  5. Hydro tec Phase II kits
    By maineidyl in forum Technical Discussion
    Last Post: 05-24-2013, 07:21 AM
