Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 55
    Baton Rouge, La
    Sometimes the one from the old pump stays on the tube. Sounds like you are on top of that. I don't understand how there can be no water making it into the motor.
    The only thing that makes any sense would be the top grommet getting fouled. You can force a hose onto the tube and the hose pressure should force water thru the system. That would eliminate a blockage above the pump. On the bright side your lower removal and install times should be greatly improved.
    Cheaters never Win !!!
  2. Likes Merc 2.5 liked this post
  3. #17
    Apr 2018
    Titusville Florida
    OK I thought Merc 2.5 was referring to the rubber insert in the water pump housing outlet. That is what 1954bmw was talking about. I think Merc 2.5 you are talking about the rubber grommet Mercury calls the Centrifugal Slinger that slides over the drive shaft after the water pump housing is installed. I took the old one off and put the new one on.
  4. Likes Merc 2.5 liked this post
  5. #18
    Dunnellon, Fl. / Cincinnati, Oh
    Forgot to ask did you actually take the boat down to the water and put it in I know there's some that have a problem with on the muffs not enough pressure or whatever but as soon as you put it in the all the way in water it's fine..
    I know mine with the low water pickups are a pain till I made one that works .. instead of wasting the $55 dollars
    Just had a jet- ski do that. Sea doo-doo spi. Old. 3 other skis idled fine, 1 Yamaha, 2 sea doo-doo gtx, temps good. 4th ski, (spi) got hot on the hose. Weird, same motors in spi and gtx, only one was fussy!?!?
    Took it to the river and ran it submersed, on the trailer, and all was well.
  6. Likes mrichartz liked this post
  7. #19
    Jul 2005
    AZ
    Quote Originally Posted by Bumblebeeman View Post
    Going to need pics or program soon think people are talking different grommets and o-rings ..lol
    Had to read that a couple times..
    '84 Checkmate Convincor
  8. Likes Merc 2.5 liked this post
  9. #20
    Jul 2005
    AZ
    Quote Originally Posted by rochelle howell View Post
    Yea amazing how you can have 4-5 however many of the same motors and there's always one fussy little b..that on the hose won't work but is perfectly fine in the water..
    I figured it would be a leaky gasket etc but you can tear it all apart go over with a fine tooth comb and nothing
  10. Likes rochelle howell liked this post
  11. #21
    Baton Rouge, La
    There is another grommet in the bottom of the adapter plate. Maybe it got fouled when the tube was reinstalled.
  12. Likes bullet123 liked this post
  13. #22
    Apr 2018
    Titusville Florida
    If that is the grommet at the top of the water tube I'm going to check that in the morning.
  14. #23
    TX......somewhere?
    trim tha motor as high as ya can.. when you reinstall tha copper tube in tha "bottom" of tha adapter plate put a dab of some kinda lub on it.. line it up and "tap" it in with a 2x or rubber mallet till you feel it seat in its grommet... that grommet has a retainer that will squash tha rubber a tiny bit sometimes.... you can see up tha tube with a flashlite.. jus takes "practice"....
  15. Likes tux974 liked this post
  16. #24
    X2 what tlwjkw is saying....but do not tap it too hard just till you feel it stop.
    I have seen where the copper tube has cut that retainer/stop ring he mentioned by some one hit too hard. Which then can float or sit in the way of water flow.
  17. #25
    Apr 2018
    Titusville Florida
    I pulled everything apart again and verified that the proper rubber seal was already installed in the water pump upper housing. I verified through Mercury's on-line parts catalog that the exact same P/N seal goes in the exhaust plate at the top of the water tube. Having just bought this 1996 200 EFI one year ago I have no idea the age of that seal. Do people ever change that seal? Is it hard to get to? A lot of disassembly?
    With a very powerful flashlight I took a picture looking up at the attachment area for the upper part of the water tube (see attached). Does this look normal? I think I can see that seal up in there.
    Any other thoughts?
    I did notice that my old water muffs seem to have lost some of their "springyness" perhaps not holding the muff sides onto the engine with some good force. I have a new one I will try that squeezes so much its hard to get on the lower unit. If it fails to pump water this will be one of the biggest most thoroughly investigated mechanical mysteries of my life. And I will bring it in to the shop.Click image for larger version.
Name:	200 EFI Upper Water Tube Attach.jpg
  18. #26
    Jun 2009
    central minnesota
    insert copper tube into waterpump ,put visegrip onto ds spline turn with hand.does water come out?? take tube off pump and insert into upper grommet,attach waterhose onto tube,turn water on,start motor,overheat now?-th
  19. #27
    Apr 2018
    Titusville Florida
    So MN808gade, to make sure I understand this right, in the turn spline by hand test, this is done with the lower unit off the engine and a water hose attached to the lower unit?
    And the second test is also done with the lower unit off the engine when I start the motor?
  20. #28
    Baton Rouge, La
    With the copper tube installed in the upper grommet in the adapter plate you can put a water hose on the tube and mine would push water thru the entire system before I started it.
  21. #29
    Apr 2018
    Titusville Florida
    The copper tube is so much smaller than the hose. Isn't most of the water just going to bypass the copper tube?
  22. #30
    Baton Rouge, La
    The id of most hoses will fit tightly on the copper tube
  1. Mercury Tech: 92 2.5 V6 with a squeaky water pump, OK or time to replace?
    By SAMMYBOY in forum Technical Discussion
    Last Post: 09-18-2019, 09:43 PM
  2. Replies: 8
    Last Post: 09-13-2019, 10:18 AM
  3. Mercury Tech: 89 200HP Mariner Low Water Pressure - water pump and hoses flow fine
    By tristanlee85 in forum Technical Discussion
    Last Post: 07-02-2018, 10:59 PM
  4. low water flow out of water out hole(ahelp please)
    By ronnyd8719 in forum Technical Discussion
    Last Post: 06-25-2007, 10:36 PM
  5. Water pump HP? flow?
    By Techno in forum Technical Discussion
    Last Post: 11-21-2001, 10:09 PM
