Page 4 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 46 to 60 of 145
  1. #46
    Apr 2015
    Oceanside, NY
    Poured in a little 2 lb 2 part closed cell foam today. Just in case. We are going to add a little more to the transom area and sponsons.
    We also started adding topside battens. We noticed our ribs were not perfect on the top sides. We had to add a few shims for a smooth transition.
ID:	457005Click image for larger version.
  2. Likes tnelsmn liked this post
  3. #47
    7 Post(s)
    Here is what we used for steering in the race boats.
    Cheap, easy, light and safe.
    This is the steering drum and the wheel bolts right to it.
    Go to Home Depot and buy some plastic coated, 1/4” beaded cable for steering cable.
    Two coaming pullies, on opposite sides, cable from drum through pullies, turns 90* and heads for motor.
    You then mount a steering bar to motor, normally on back, at top of mid section, and bottom of Powerhead.
    Mount one additional pulley to each end, then run cable through them.
    Can run either direct which means the tail of cable loops around steering bar pulley and clamps to itself.
    In direct would have cable tail secured back to coaming just forward of transom. Indirect gives better leverage for s heavy/powerful motor line your running.
    Go to hydroracer.com for pics.
    On set up, once correct, the back of the sponsons should be 2” - 3” off the water.
    You will control this but moving your body fore and aft on the floorboard, while driving in your knees.
    Youll want knee pads.
    By moving the C. of G. and flying the bow is what makes 3 point hydros so fast.
    I have photos but don’t know how to load from my phone.
    BTW, the steering drums are very easy to make if you have access to a fab shop.
    Quote Originally Posted by Seanj85 View Post
    Ronnie, we are going to need cable steering. I am looking around online and am having trouble locating something. I could probably rig up some redneck home made stuff but I want the steering to be legit as possible. There is a lot of power on the back of this boat. I have been keeping an eye on local stuff via craigslist put pickings are slim.
    Attached Thumbnails Attached Thumbnails 63F1194A-479F-429E-8B8F-CD9AA67FA20D.jpeg
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  4. #48
    Apr 2015
    Oceanside, NY
    Great stuff, thank you. I do not have access to a metal shop to make a drum outside of my woodshop here, I am assuming it has some sort of bearing inside of it. Where can I buy a decent one?
  5. #49
    7 Post(s)
    Yes they have a bearing in them.
    I just bought the one in the pic I posted.
    PM me your address and when it arrives, I’ll forward it to you and the kids.
    I have 9 yrs exp racing that type of boat, as well as design/build.
    Happy to help you w/set up if you like.
  6. Likes Merc 2.5, Seanj85, rock, Mugs914 liked this post
  7. #50
    Apr 2015
    Oceanside, NY
    Thought I would post a few progress pics. It is midterm week and a few students have come in to work in-between tests.
  8. Likes 89LASER, tnelsmn liked this post
  9. #51
    Apr 2015
    Oceanside, NY
    PM Sent, thank you for the help
  10. Likes Instigator liked this post
  11. #52
    7 Post(s)
    Just got the steering drum.
    Packed so well I’ll just change labels and send it your way Sean.
    Should go out tomorrow.
  12. Likes rock liked this post
  13. #53
    Apr 2015
    Oceanside, NY
    Started buttoning up her top sides today. Sponsons are finally done and top battens are finally added. We were originally going to staple down the top sides with staples from the air gun, but the pos harbor freight gun decided to quit on us 3 staples in. So we made a quick switch to using an old school spring loaded staple gun. The top sides are only 1/8 inch thick so nails would have pulled right thru. We pulled the boat out into the hallway to staple down the piece of ply, this way we know we were on some solid level ground. I am very happy with how she sits on land, with 4 points of contact. I took a few measurements and the two sides are nice and even. Attached are a few pics from the past week or so.
ID:	457481Click image for larger version.
ID:	457482Click image for larger version.
ID:	457483Click image for larger version.
ID:	457484Click image for larger version.
ID:	457485Click image for larger version.
  14. Likes home made tunnel, 89LASER, tnelsmn liked this post
  15. #54
    Rhode Island
    eXCITING! Should be ready to go for spring time !!
  16. #55
    7 Post(s)
    Looks great Sean.
    Stapling is the only way to skin one of those.
    A hammer will bounce off the deck/battens before you drive a single nail.
    Done right, nails/staples are only clamps until the glue dries anyhow.
    BTW, your steering drum went out yesterday.
  17. #56
    Apr 2015
    Oceanside, NY
    Thank you Gary. It came in today.
    You are the best!
  18. #57
    7 Post(s)
    Glad you got it.
    Youll still need a set of coaming pullies and steering bar pullies.
    The bar pullies are easy to come up with.
    Coaming pullies you’ll have to watch for.
  19. #58
    Pekin, IL
    Very true.
    Team Junk
  20. #59
    Black Creek WI
    Hull drain's? Not to take away from a great job, but wondering if you are putting hull drain plugs in and if the form placement would cause problems in draining any water the hull may take on in the sponsions, as that's the lowest point and it is foamed now
    1994 Brad Collins Mirage Jag.with 1990 2.4 BP E.F.I Offshore
  21. Likes Instigator liked this post
  22. #60
    Apr 2015
    Oceanside, NY
    Quote Originally Posted by wogi View Post
    Oh shoot. I forgot about drains. I guess we will have to drill them in on sponsons and transom, but I didnt think about the foam getting in the way. I was planning on drilling a few 4" holes inside of girders so that a hand pump can get access. But this may be a problem being that we closed in the top sides today.
    Should we open it back up and cut a trench?
ID:	457625Click image for larger version.
  23. Likes tnelsmn liked this post
  1. OMC Tech: School Me On Old School ('50's) 2 Banger JohnRudes......
    By Instigator in forum Technical Discussion
    Last Post: 01-14-2015, 07:48 AM
  2. Hydroplane,,an old one.
    By Eagle127 in forum General Boating Discussion
    Last Post: 03-09-2013, 09:00 AM
  3. Old School V.S. New School Paint
    By EVILWAYS in forum General Boating Discussion
    Last Post: 07-29-2009, 02:24 PM
  4. jet hydroplane?
    By KEVIN NICHOLS in forum Technical Discussion
    Last Post: 04-01-2003, 06:57 PM
