Page 3 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 31 to 45 of 145
  1. #31
    Apr 2015
    Oceanside, NY
    Quote Originally Posted by home made tunnel View Post
    Congrats on being a Daddy! That's Huge! I'm a new dad as well, and love seeing little wooden boat projects like this.
    Sure is a neat little vessel.
    Prior replies were correct about the stressed skin style boats - you can see in my pictures that I had made a jig to hold my tunnel sides straight and level when I was building my boat. This is what they were talking about.
    I don't think it's necessary in your case, being a smaller fun vessel, but regardless it's still coming out great!
    Attachment 456093Attachment 456094Attachment 456095Attachment 456096
    I saw your build thread, awesome stuff! What kinda performance are you getting out of that thing!??
  2. #32
    Apr 2015
    Oceanside, NY
    Flipped the hydro over today, sat her on level ground and it looks good. No twists, sponson afterplanes are both touching ground along with the pad on the transom. Next the plans call for some shoring before we add 3 layers of spar varnish over the interior. Once that is done we can add top battons and 1/8" meranti ply decking on top sides. We finished up nose cone on the frankenmerc, dont look too hard, it's not beautiful as the kids faired it. Just have to finish up a little electrical stuff on it. Project is moving along nicely.
ID:	456453Click image for larger version.
ID:	456454Click image for larger version.
ID:	456455Click image for larger version.
  3. Likes wogi, tnelsmn, 89LASER liked this post
  4. #33
    Black Creek WI
    A+ for workmanship
    1994 Brad Collins Mirage Jag.with 1990 2.4 BP E.F.I Offshore
  5. Likes Seanj85 liked this post
  6. #34
    Minneapolis MN
    Looks great, proud group of kids there! Glad youngsters these days are still able to get their hands dirty and build a project like this.
  7. Likes Seanj85 liked this post
  8. #35
    Pekin, IL
    Lookin good. Can't hardly wait to see the finished product. Are you going to paint it or just clear it?
    Rock
    Team Junk
  9. #36
    Apr 2015
    Oceanside, NY
    Quote Originally Posted by rock View Post
    Rock
    Hard to say, I love the clear coat look, but I dont know if our work will be good enough for a clear. I have a student who works at a place that does decal wraps, we may try to wrap it. If that doesnt work then paint.
  10. #37
    Dec 2001
    2 things I will add....If ya can tie in the bulkheads in front of the dashboard.....and if ya want I have a 15 inch mid...that looks like a 20 inch......Great work.....Allways wanted to build one.....Me WOOD BUTCHER.......so I never tried.......
  11. #38
    Apr 2015
    Oceanside, NY
    Hahahaha
    Not sure what you mean by tieing in bulkheads in the front. We are going to add some structure when we do the steering and whatnot up in the bow, still a ways away from there though.
    I know it doesnt look like it but the motor is already a 15 inch shaft. We put it on the boat temporarily just to be sure as we made the transom 19 inches for a surfacing prop and low water pickup. Maybe you guys could give me your thoughts on motor height, we can still come up a bit with some shims, I'll try and include some pics.
ID:	456543Click image for larger version.
ID:	456542Click image for larger version.
  12. Likes 89LASER liked this post
  13. #39
    Rhode Island
    Quote Originally Posted by Seanj85 View Post
    I've come close to 70, but I have way too much weight in the rear still. I relocated the battery to the front, but the fuel tank has to go up there also. The bare hull weighed 505 lbs, and the motor is just under 400 lbs. Plus hydraulic steering setup. Plus the jack plate. I probably have close to 450 lbs hanging on the transom.
    I say I need more weight forward because it still porpoises around 60mph. I've messed with all sorts of props and engine heights. Too high, and I cant even get on plane. Too low, and she's slow. I'm sure I have the right height and prop, now I just need to work on the balance.
    Wood Butcher. I love it. I think that may be the name of my tunnel hull that I haven't named yet... GENIOUS, DAVE!!!
    Hahahaha
    2" below the pad is usually a good starting point. Many members have good luck with that as a rule of thumb to start with. If you have cavitation issues getting on plane... drop it a bit. If not.. just monitor water pressure.
  14. Likes Seanj85 liked this post
  15. #40
    Dec 2001
    I see the lower unit is a 15..... sorry my bad.....Most 3 clys I have seen were 20 inchers.....
  16. #41
    longisland
    Great to see theres still a school on Long Island that still has a shop program. best of luck with the project. what else is need to complete the project that we all can help with?? parts we all have in the shop and shed??
  17. #42
    Black Creek WI
    Who gets to do the testin ?
  18. #43
    7 Post(s)
    Try some stain before painting it.
    You might be surprised how good it looks.
    You can come up w/some stripes to hide boo boo’s if you need to.
    As light as that boat is, you should be able to run the propshaft even and it will still jump in plane.
    If the motor will pump water that high.
    Start watching e-bay for props. You’ll want as much ouch as you can find.
    Watch gas tank size, weight and placement. It will have a huge effect on attitude and performance.
    Keep it aft if you can.
    The hull will build lift and try to carry the bow at speed.
    We Used to run real small, 2 or 3 gal tanks mounted right against the transom.
    We also had some tanks that hung on the back of the motor.
    Make sure and wire a kill switch and run a dead mans throttle that returns to idle/close if let go of.
    That thing should be wicked fast w/that motor.
    Be careful.
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  19. Thanks Seanj85 thanked for this post
  20. #44
    Apr 2015
    Oceanside, NY
    Quote Originally Posted by RONNIE View Post
    Ronnie, we are going to need cable steering. I am looking around online and am having trouble locating something. I could probably rig up some redneck home made stuff but I want the steering to be legit as possible. There is a lot of power on the back of this boat. I have been keeping an eye on local stuff via craigslist put pickings are slim.
  21. #45
    Apr 2015
    Oceanside, NY
    Quote Originally Posted by wogi View Post
    I am going to to test it with another member of my department first. If it is safe we will then let students test it (so long as they have their boaters safety course). I will have my boat out as the mothership and command center of the operation. Some detuneing may be in order.
  22. Likes Instigator liked this post
  1. OMC Tech: School Me On Old School ('50's) 2 Banger JohnRudes......
    By Instigator in forum Technical Discussion
    Last Post: 01-14-2015, 07:48 AM
  2. Hydroplane,,an old one.
    By Eagle127 in forum General Boating Discussion
    Last Post: 03-09-2013, 09:00 AM
  3. Old School V.S. New School Paint
    By EVILWAYS in forum General Boating Discussion
    Last Post: 07-29-2009, 02:24 PM
  4. jet hydroplane?
    By KEVIN NICHOLS in forum Technical Discussion
    Last Post: 04-01-2003, 06:57 PM
