Results 1 to 10 of 10
Thread: Lithium and Merc R motors ?
09-12-2019, 06:17 AM #1Member
- Feb 2003
- 85
Anyone running a lithium battery with the new V8 Merc's.
I had recently purchased a new 125 AH lithium now I'm repowering with a 250R... Mercury recommends an AGM--- Sure hate to pull that high dollar light wt investment.
09-12-2019, 07:06 AM #2
My boss has 2 36 volt lithium batteries linked together for his trolling and loves them, with the stealth charger they never die, he told me that the 12 volt batteries are crap and a waste of money, did not perform like he had hoped, if you let them set to long with out use you have to(awaken) them before they will operate, I would not buy a12 volt for the money, stay agm
(Rip. Whiteally02) -dad
09-12-2019, 07:52 AM #3Screaming And Flying!
- Sep 2001
- shreveport,la
- 5,706
- 118
- 85
- 773
09-12-2019, 07:58 AM #497 xb2002 15" 300x w 1.62 sporty
09-12-2019, 08:17 AM #5Member
- Feb 2003
- 85
Not concerned with the trolling batteries- I have three 12 volt 50 Ah for a 36 volt trolling mtr that are awesome.
My concern is with the starting battery... Mercury HIGHLY recommends an AGM of 975 or greater CCA .. The 125AH lithium has worked fine with my old 3.2 ltr 300.
What I'm hearing---The motor puts out too much voltage when running for the BMS. It could trip the BMS high voltage cutoff. When that happens your battery shuts off and then the motor shuts off. Not something you want to happen at wide open throttle
09-12-2019, 08:20 AM #6
Agreed,
05-29-2020, 07:40 PM #7
Where did you find a 125 AH lithium battery? Most of the ones I've seen while researching are between 12 AH and 20 AH. I am seriously considering lithium for the light weight in my 14 Allison. I've been looking at Full Spectrum Power Batteries and Antigravity. I was going to install a regulator to prevent charging more than 14 volts and damaging the battery. It's a carb motor with no ECM. I was thinking the built in shut off with reset button would eliminate the need for a battery switch and trickle charging when not in use. People are starting Porsche flat 6s and Ferrari V12s with these batteries that weigh between 3 and 10 lbs!!! The race motorcycle batteries weigh 12 oz. will start a Hayabusa! That's amazing.
2004 Hydra-Sports Vector 2600 - twin 225 Yamahas
06-01-2020, 06:59 AM #8Member
- Feb 2003
- 85
Lithium Hub Has them .. Ionic is the brand.
06-01-2020, 09:34 AM #9Screaming And Flying!
- Sep 2001
- shreveport,la
- 5,706
- 118
- 85
- 773
Unless you’re cranking something with crazy compression you can get by on less than 10 lbs. I used to crank a 2.5 with 250 lbs of compression with a 16 cell Ballistic battery that weighed 3.5 lbs. I later switched to 24 cell Antigravity batteries and loved them. Look at the 24 or 30 cell Antigravity. On a normal lake engine you’d probably have a hard time killing it
Erik Kiser
06-03-2020, 06:03 PM #10
Thanks I'll check it out.
Lithium Batties
By jpf091959 in forum General Boating DiscussionReplies: 31Last Post: 06-28-2015, 09:56 AM -
anybody here using lithium batteries on there boat ?
By frontline in forum General Boating DiscussionReplies: 13Last Post: 03-31-2015, 06:49 AM -
lithium battery charger
By bullwhipjkg in forum Misc. Parts and AccessoriesReplies: 1Last Post: 12-11-2014, 08:23 PM -
Mercury Tech: Lithium ion starting batterys
By bigbluechevy454 in forum Technical DiscussionReplies: 6Last Post: 07-11-2013, 07:18 PM
