Results 1 to 7 of 7
    Feb 2003
    Lithium and Merc R motors ?
    Anyone running a lithium battery with the new V8 Merc's.
    I had recently purchased a new 125 AH lithium now I'm repowering with a 250R... Mercury recommends an AGM--- Sure hate to pull that high dollar light wt investment.
    Oct 2018
    Tennessee
    My boss has 2 36 volt lithium batteries linked together for his trolling and loves them, with the stealth charger they never die, he told me that the 12 volt batteries are crap and a waste of money, did not perform like he had hoped, if you let them set to long with out use you have to(awaken) them before they will operate, I would not buy a12 volt for the money, stay agm
    97 xb2002t-3.4 etech 250 ho
    shreveport,la
    Quote Originally Posted by Will hedrick View Post
    There is nothing inherently wrong with a 12 volt lithium battery. A 36 volt battery is made up of the same cells that make up a 12 volt.
    Erik Kiser
    Oct 2018
    Tennessee
    Quote Originally Posted by patchesII View Post
    I can't disagree, he told me that he would not own another 12 to run as a cranking battery, it gave him to many problems as a cranking battery.
    Feb 2003
    Not concerned with the trolling batteries- I have three 12 volt 50 Ah for a 36 volt trolling mtr that are awesome.
    My concern is with the starting battery... Mercury HIGHLY recommends an AGM of 975 or greater CCA .. The 125AH lithium has worked fine with my old 3.2 ltr 300.
    What I'm hearing---
    The motor puts out too much voltage when running for the BMS. It could trip the BMS high voltage cutoff. When that happens your battery shuts off and then the motor shuts off. Not something you want to happen at wide open throttle
    Oct 2018
    Tennessee
    Agreed,
    Central NJ
    Quote Originally Posted by fishnfireman View Post
    What I'm hearing---
    Where did you find a 125 AH lithium battery? Most of the ones I've seen while researching are between 12 AH and 20 AH. I am seriously considering lithium for the light weight in my 14 Allison. I've been looking at Full Spectrum Power Batteries and Antigravity. I was going to install a regulator to prevent charging more than 14 volts and damaging the battery. It's a carb motor with no ECM. I was thinking the built in shut off with reset button would eliminate the need for a battery switch and trickle charging when not in use. People are starting Porsche flat 6s and Ferrari V12s with these batteries that weigh between 3 and 10 lbs!!! The race motorcycle batteries weigh 12 oz. will start a Hayabusa! That's amazing.
    1988 Chris Craft Stinger 313 twin 2004 225 Evinrudes
    1994 Activator 14 Allison Copy / 1988 Merc 115 Tower w 15" mid
  1. Lithium Batties
    By jpf091959 in forum General Boating Discussion
    Last Post: 06-28-2015, 09:56 AM
  2. anybody here using lithium batteries on there boat ?
    By frontline in forum General Boating Discussion
    Last Post: 03-31-2015, 06:49 AM
  3. lithium battery charger
    By bullwhipjkg in forum Misc. Parts and Accessories
    Last Post: 12-11-2014, 08:23 PM
  4. Mercury Tech: Lithium ion starting batterys
    By bigbluechevy454 in forum Technical Discussion
    Last Post: 07-11-2013, 07:18 PM
Bob's Machine
