Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
    Jul 2005
    AZ
    There are a bunch of different kinds of construction adhesive alot have pretty much the same color can confuse one with another... some if they get wet or frezze before they cure they turn to crap..
    No matter what it was they used the wrong stuff..
    Even if it was liquid nails once the wood rots you wouldn't need tools to pull it apart the adhesive is only as strong as what it's attached to.
    '84 Checkmate Convincor
  2. #17
    Jul 2005
    AZ
    Quote Originally Posted by Gordon02 View Post
    Guys, I've used Liquid Nails only a few times and am certainly no expert with it's identification or application. What I pulled apart in the floor of this boat is brown and does look like what I remember coming out of my caulking gun when building my shop. Here are some more photos showing where this "brown stuff" was used. I pulled the wooden cross braces out of the rotted wood and from the construction adhesive by hand. No hammer, no crowbar, just grab and pull up. Perhaps this adhesive was not meant for wet environments? Have a look for yourself below where I've circled the brown stuff. Gordon
    Attachment 448709Attachment 448710Attachment 448712
    What's the rest of the wood look like?
  3. #18
    Sep 2017
    Ashland city tn
    I wasnt tryin start a match over liquid nails, just didnt think it turned to mush n water. Either way we know its gotta come out and rite stuff go in. Good luck with ur buid Gordon and keep us in pics
  4. Likes mrichartz liked this post
  5. #19
    Jul 2005
    AZ
    Quote Originally Posted by Merc 2.5 View Post
    Yea all I was saying was it stays flexible...
    But what happens to it when under water for extended periods of time who knows,?
  6. #20
    Jan 2018
    Alabama
    It's all gotta go. Here is some updated photos from yesterday where I've cut the glass along the sides and have peeled the glass away from the two short stringers. I've got friends coming this weekend to help lift the boat from the trailer and set it on the grass so the hull will be supported and I can get inside and finish the cutting and grinding to have a clean, bare hull. I'll then shape new White Oak stringers. White Oak will not absorb water - it's been the wood of shipbuilding for hundreds of years. I shape it, make all the cuts, then saturate all surfaces with Rot Doctor's thin penetrating epoxy (CPES), then lay the stringers into a thick bed of epoxy "peanut butter" under weight. I'll be posting those updates in the Build forum under the GT150 thread - Gordon
ID:	448714Click image for larger version.
  1. Balsa core lamination
    By Gmcviper in forum Fiberglass and Composites Discussion
    Last Post: 04-27-2017, 08:18 AM
  2. Lamination experts, Question for you!
    By xsflight in forum Fiberglass and Composites Discussion
    Last Post: 05-09-2010, 01:21 AM
  3. Krauthammer Nails It!
    By MIJI in forum The Scream And Fly Lounge
    Last Post: 03-06-2009, 09:40 AM
  4. What liquid in liquid-filled Gaffrig?
    By Markus in forum Technical Discussion
    Last Post: 04-05-2002, 01:27 PM
