Results 1 to 9 of 9
    Oct 2015
    Kentucky lake
    Merc V6 running compression #s Wats good?
    I've got a 2.4 that's running at 145psi all 6 with engine running at 1,100 rpm is that about right it has 120psi cranking all 6 just checking thanks Keaten
    Dunnellon, Fl. / Cincinnati, Oh
    I've got a 1988 2.4 175 hp. that shows 130-135 cranking compression on my gauge.
    Sep 2017
    Ashland city tn
    I wanna say keaton 2.4 had 130 psi cold cranking, 120 warm
    I've never checked comp running on a outboard, so really wouldnt no what to expect. Sure it will b higher tho
    Not to change subject but if mota has 145 -150 wonder what's its pumpin out runnin?
    Dec 2004
    Massapequa, N.Y
    Might be a silly question guys, but how do you check compression while engine is running? Are you just running it on 5 cylinders with the gauge in the 6th?
    Sep 2017
    Ashland city tn
    Quote Originally Posted by stream18 View Post
    I guess that's only way to check that I know of
    Oct 2015
    Kentucky lake
    Yes I have nothing against cranking speed PSI checking. It just seems more natural and meaningful to test the cylinder and ring health this way. I only run it for about 10 Sec per cylinder @ 1,000 rpm. After proper warm up on water hose. Works great for me. Thanks Keaten
    Oct 2015
    Kentucky lake
    Quote Originally Posted by Merc 2.5 View Post
    Yes that's correct
    Dec 2017
    Lake Ashby, New Smyrna Beach FL
    In every type of engine you should check compression when the engine is at operating temperature.
    Engine doesn't have to be running. Get it hot, pull the plugs and go cylinder to cylinder. Turn the engine over 5 or 6 seconds. This will send the pistons up and down several times.
    I have 2 gauges that read the same. I do 2 cylinders at a time.
  9. Likes Captain75 liked this post
  10. #9
    MIAMI FLORIDA
    Not gonna tell u anything on a 2 stroke engine... the best compression test is to only let it pump 3 or 4 times and do them all the same, no extra pulses for the lazy ones... Cranking on a cylinder until it finally makes it doesn't count to me and running would pretty much do that. That said this is a cylinder/piston condition test so yes you may crank it over 8 or10 times and get a little more if your looking to see what your peak compression # is for tuning . A compression test is to look for a given loss that's going to be amplified and rob hp when the cyl pressure is 10x the cranking at max rpm # faking it will only slow u down.. jmho.. Dave
  11. Likes Captain75 liked this post
  1. Cranking vs. Running Compression
    By Mr. Demeanor in forum Technical Discussion
    Last Post: 10-14-2014, 05:53 PM
  2. wats happen to this progression
    By jersey in forum General Boating Discussion
    Last Post: 10-22-2010, 02:12 PM
  3. if compression is good is motor good?
    By egotsofas in forum Technical Discussion
    Last Post: 09-08-2008, 08:02 PM
  4. what is a good compression for a stock 1991 2.5 merc 200hp
    By camaro7081 in forum Technical Discussion
    Last Post: 09-09-2006, 06:36 PM
  5. Cost of running hi compression?
    By Techno in forum General Boating Discussion
    Last Post: 01-24-2004, 12:02 PM
