Results 1 to 13 of 13
    Jan 2009
    Long Lake, NY
    Head Gaskets, right or wrong?
    Hi Everyone,
    I have an older 2.4 225, probably around '81 or maybe '82, serial # 517073. Number 6 cylinder head gasket blew right out, causing loss of compression in that cylinder. I looked up the part number for new head gaskets found the following 27-96541 which supersedes to 27-41244T02. I get the new head gaskets today and I compare them with the old, blown one, there is a slight difference. The smaller water h9oles are smaller on the newer gasket than on the gasket I took off. Are these new gaskets updated compared to what was there? Is it ok to run them without having any trouble or should I send them back. See attached photos for the difference.
ID:	448629Click image for larger version.
ID:	448630Click image for larger version.
  2. Likes rochelle howell liked this post
    Dec 2001
    you are lucky to get gaskets for that old of a motor..... use em'.......later merc gaskets are nla.....prob les holes for better control of side movement..... The only take # 30 lbs on old motors.... make sure the heads are flat/w in .20......
    Dunnellon, Fl. / Cincinnati, Oh
    That's a big difference, I'd question that, also.
    Sep 2017
    Ashland city tn
    Get the right gasket. I just ordered 2 of the old schools little less than yr ago. They r still out there. , make sure gasket has all them holes like old one
    I guess it does have all its holes but smaller , looks fishy, if I couldn't find the correct match then I'd try it
    Jul 2002
    FT WORTH, TEXAS
    ive been to the dance your in i agree totally with Dave use them because there are no right gaskets for the nearly 30 year old motor if you can find them at all and parts availability is getting smaller every year. i had several of this style early block and every stinking one of them leaked the last ones i had i got head gaskets from promarine and they were a good 1/8 inch too big all around the perimeter of both heads i made a couple phone calls to tech department but there were no options except mercury and head gaskets cost more from them then i gave for the complete power .here is what they told me to do we know how big they are being manufactured but no one else will make them any more just use the peanut butter style sealant (thats what us old guys called its purple with brush attached the cap and very messy ) on it and if it leaks we will give your money back and the both leaked on the perimeter bolts i kept tightening them and they finally quit many of that style block has the head bolt boss's on the sleeves that are distorted and will never seal good luck mister
    Dec 2001
    I like the prupple/bush.... but I use red in the spraycan.....just make sure the head is flat........
    Sep 2017
    Ashland city tn
    If Texas says run it then u will b fine
  9. #8
    Those are fine..if anything they help keep the water block side longer.
  10. #9
    Jan 2009
    Long Lake, NY
    Look at what I found..... Click image for larger version.
ID:	448713 note that the part number on this picture is the exact same part number I ordered and received. Thank you all for your replies and input. I guess I'm just going to use what I have and take it from there..........................John
  11. #10
    Sep 2017
    Ashland city tn
    Quote Originally Posted by LLEnchanter View Post
    I knew I ordered 2 while back as a direct replacement
  12. #11
    Jan 2009
    Long Lake, NY
    Thank you everyone, all you input is valuable. I put those gaskets on, started the engine and let it run for a few minutes, then went to re-torque the head bolts. I did not really like the way they torqued in the first place, but when re-torquing, I really didn't like. I've decided to order new head bolts, which I should have done in the first place. Thank you again for your input, You all take care.
  13. #12
    Sep 2017
    Ashland city tn
    B very careful torquing those heads. It will damn near pull sleeve out! Not really but will warp it, the bolts go in cyl
  14. #13
    Aug 2005
    West Allis,Wisconsin
    Merc HP gasket on Ebay. Part # 27-18350 they are a tad thinner.
  1. Early Merc 2.0 Head Gaskets and Water Jacket Gaskets
    By silverbullet02 in forum Misc. Parts and Accessories
    Last Post: 10-25-2018, 07:11 AM
  2. 2.5 Head Gaskets?
    By K-Dawg in forum General Boating Discussion
    Last Post: 06-15-2008, 05:19 AM
  3. Head Gaskets
    By vnemous in forum Technical Discussion
    Last Post: 12-07-2006, 06:24 PM
  4. 3l 225 head gaskets?
    By sinista in forum Technical Discussion
    Last Post: 11-23-2006, 06:29 AM
