Results 1 to 14 of 14
Thread: Gauges on opti
09-11-2019, 03:09 PM #1
Gauges on opti
Can gauges that worked on a 1993 2.5 EFI , work on a 2018 3.2 Optimax? Water pressure, temp ,tach. Gauges are newer auto meter
1986 cougar mtr 21
2003 supra launch ssv
09-11-2019, 09:40 PM #26000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
Yes and no.
Need analog senders and the harness
09-13-2019, 05:20 PM #3
I'm switching everything over to digital and rewiring the whole boat so have some sense of how it works and what the differences are. Mine had the 15 pin round to 8 pin round adapter (84-896542A01) and the old style 8 pin boat harness. The tach works fine didn't have water temp but I don't think that goes through the harness and the pressure gauges are mechanical so also work fine (should be a plugged tee near the rigging tube.
96 Cougar 23 MTR twin 300XS's. 100 something
98 Laveycraft Sebring 20.2 Tunnel 280 90 something SOLD
85 Baker RST 220 Laser SOLD
09-13-2019, 05:53 PM #4
09-18-2019, 05:35 PM #57000 RPM
- Feb 2005
- seattle
- 2,654
- 17
- 33
dont go with a digital trim guage. they are slow to read the actual trim.
09-18-2019, 05:53 PM #6
I'm kinda committed to digital trim at this point. What are you basing that on? Display on an SC1000? I am going with the Livorsi LED indicators. I hope it's not a problem because that little box is stupid expensive!
Thanks for the heads up and I will report back when I get it up and running.
11-01-2019, 07:58 PM #7
I didn't have any trouble with the digital indicators on trim. They seem very responsive and the ability to calibrate the full down, full up and a sweet spot marker is a bonus. I set the full up to be about beaching height as I don't need an indicator any higher than that. Now I have to make senders for the jack plates to get those indicators working.
11-02-2019, 11:34 AM #85000 RPM
- Apr 2011
- Western NC
- 113
11-02-2019, 01:40 PM #9
11-04-2019, 12:38 PM #105000 RPM
- Apr 2011
- Western NC
- 113
11-04-2019, 03:33 PM #11
I'm surprised it's not available because there is no simple way to get the digital output to work on an analog gauge. I thought I saw a thread on changing the digital to analog sender but can't find it now so you are probably right. You might have to use something like this 8M0099687 analog gauge interface.
11-04-2019, 04:45 PM #125000 RPM
- Apr 2011
- Western NC
- 113
Whats odd is the Water temp, Tach and volt work. Are they digital? This rig is new to me and I have not torn into it yet.
11-04-2019, 05:35 PM #13
You probably have the 14 pin to 8 pin adapter under the cowling. That allows you to use the older style 8 pin harness which takes care of the tach and volts is volts so it works anyway. Not sure about the temp but there is a 4 wire temp sender that has both the digital and also the brown lead for analog. Here is a link to a manual (90-898305) that has a bunch of info. Check page 31 for the trim sender note that made me think you just had to change the sender. Page 32 talks about the temp. It says 135 through 250 so may not apply to the 300's but worth checking.
https://www.google.com/search?client=firefox-b-1-e&biw=1366&bih=614&sxsrf=ACYBGNQIn0dV2KaGUSRsby6k_4Vv-EuGzg%3A1572905648070&ei=r6LAXbjKOcLE0PEPsr64-AY&q=analog+tmp+optimax&oq=analog+tmp+optimax&gs_l=psy-ab.3..33i160.17547.39032..39536...0.0..0.143.2282.0j18......0....1..gws-wiz.......35i39j0j0i67j0i131j0i20i263j0i22i10i30j0i22i30j0i13j0i13i30j0i8i13i30.aHqspCoMgAg&ved=0ahU KEwj43aSTytHlAhVCIjQIHTIfDm84ChDh1QMICg&uact=5
Select the PDF or search for 90-898305
11-05-2019, 11:21 AM #145000 RPM
- Apr 2011
- Western NC
- 113
Regular 225 Opti vs 250 Opti XS
By stingray240cs in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 9Last Post: 02-06-2018, 03:28 PM -
sst 120 mid or 200 opti max ros
By rapidcraft22 in forum Parts WantedReplies: 0Last Post: 06-22-2016, 10:59 AM -
Dual Repower 225 opti, 225xs or 250xs/opti
By fishnchips in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 10Last Post: 02-18-2008, 08:18 PM -
200 opti.--225 opti.???
By popslavaz in forum Technical DiscussionReplies: 2Last Post: 09-27-2005, 06:33 AM
