Results 1 to 6 of 6
Thread: Shifter adjustment
09-10-2019, 07:03 AM #1Member
- Sep 2019
- madison wisconsin
- 31
- 10
Shifter adjustment
I recently purchased my first boat and have had issues from the start with shifter after lots of adjustments and finally new mecury premium gen 1 cables it operates smoothly. With the control at full throttale at the council i am still about a 1/4 way shy of wot on the.butterflys. i treid to.move the cable in the.control box closer to the fulcrum to get more travel from the control. Both cables were.in.the outer holes in the control box . When running it like this it would rev fastand just grind gears as it was ahead of the shifter. Am i going about this correctly or is there another way to be adjusting this. I believe its a comander 3000 style with a warm up lever. Engine is an 02 merc 50hp triple
09-10-2019, 07:08 AM #2
The adjustment is on carb linkage, need to get u a manual and do link and sync
09-10-2019, 07:12 AM #3Member
- Sep 2019
- madison wisconsin
- 31
- 10
Will i need to do this with vacuum gauges as i did not see any ports like on a motorcycle
09-10-2019, 07:45 AM #4
Link and sync is just getting wot and timin set correct, butterflies should have a rod with adjustments that connect carbs that work butterflies , not familar with ur mota but shouldn't b to different. no gauges needed except dial indicator if u mess with timin
09-10-2019, 10:52 PM #56000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Compress the cable end when adjusting the barrel nuts.
Its an an easy to forget step or I see it a lot.
That compression is what alows the gang throttle/shift to shift befor picking up throttle.
Also so check for excessive movement in the case. Had one that wasn’t zip tied up the same after a steering cable swap and blew the remote synch from excessive movements.
09-11-2019, 11:54 PM #6Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
the cables should be on the outter most conectin from the fulctron.... more throw.......
shifter adjustment and reverse...
By cocacola in forum Technical DiscussionReplies: 28Last Post: 07-21-2012, 12:09 PM -
TPS adjustment 95 XRI
By THEFERMANATOR in forum Technical DiscussionReplies: 7Last Post: 05-03-2008, 07:49 PM -
Gaffrig Single Stick Shifter Or Dmp Shifter
By a.j. scoggins in forum Props, Setup, and RiggingReplies: 0Last Post: 03-11-2008, 03:23 PM -
TPS Adjustment
By Tiller in forum Technical DiscussionReplies: 23Last Post: 07-29-2003, 05:12 PM -
TPS adjustment
By Terry Jackson in forum Technical DiscussionReplies: 2Last Post: 03-28-2003, 09:51 AM
