Results 1 to 5 of 5
Thread: EGT/Pyrometer
    Sep 2018
    Derby ny
    EGT/Pyrometer
    Looking for two new EGT/Pyrometer gauges i have all the other stuff. Just wondering what you guys will recommend name brand and its accurate Thanks
    KOSO!!! http://www.exhaustgas.com/ProductDet...pID=&BasketID= About the best on the market.
    Koso Dual EGT Kit for 2.5L Mercury Outboard.Kit Includes:
    Koso Dual EGT Gauge w/ Max Recall & Alarms
    (2)1/8" Stinger Hyper Response EGT Sensors
    (2)Mercury Rifle Bolts w/ Nuts & Ferrules
    (2)EGT Patch Cord's Up to 20 feet. (Custom Lengths available)
    Instrument Manual
    Instrument Mounting Bracket
    Instrument Power HarnessKoso is synonym of quality and performance. Our company design and manufacture high quality gauges and accessories for more than 20 years for aftermarket and major OEM companies.
    Pushing the limit further by continuously improving and developing new products is our main goal. In order to reach our goal, we work with the best engineers and testing equipment available.
    We are proud to be the leader in digital technology and to offer to our customers the best and most reliable products on the market.
    EGT has access to the entire Koso line so if you don't see what your looking for....... Give Us A Call 1-800-348-4678.
    Gauge Spec's:
    • Requires 12v AC/DC
    • Measures 4.750"L X 2.250"H X 1.00" DEEP
    • LCD Size 1.750" X .750 Each Readout
    • Temp Range from 250F-1999F
    • Record's max temp
    • Celsius or Fahrenheit
    • Settable Temperature Warning
    • Backlighting Flashes from blue to red in over temp conditions
  3. Thanks Little boat that could, powerabout thanked for this post
    Another good company I've had good luck with is the sensor connection. They make this gauge in single and dual. I've used them before, quick response time and blends in well with the other round gauge's in the dash cluster.
    http://thesensorconnection.com/egt-e...-gauge-display
    I bought this one, deals with both banks on two motors.
    http://thesensorconnection.com/gauge...yrometer-gauge
    And run this display, all 4 as EGT ...
  5. Thanks powerabout thanked for this post
    Sep 2014
    Iowa
    Do these adapt to standard K-thermo wire somehow? I've been looking at the round 2 EGT for the Max temp feature. Currently have a livorsi dual pyro with K wire but it doesn't have a max feature which means the pyro is usually the last thing I look at when running hard (Water press, water temp, then rpm, then pyro). J
    Quote Originally Posted by JCSmile View Post
    Click the link .. start reading !
  1. Pyrometer
    By Hydropromax in forum Technical Discussion
    Last Post: 10-16-2005, 06:43 PM
  2. ? on a pyrometer
    By merc326 in forum Technical Discussion
    Last Post: 05-18-2004, 07:25 PM
  3. Need Pyrometer Help!!
    By Instigator in forum General Boating Discussion
    Last Post: 07-31-2003, 12:00 PM
