Results 46 to 49 of 49
09-11-2019, 07:04 PM #46
Well looks like a bp block , not sure y it's got 5 pedal front half guess someone put it.on there at sumpoint , 2.5 b better build but the old bp ran gud if built back like suppose to b
09-11-2019, 09:19 PM #47Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
a load of changing for a not so experienced motor contestant and i mean that in a nice way as you will be a contestant trying to win a up hill battle !!!! horn equals different front, injectors, reed plates hold downs, harness , ecu external tpi unless you go with a digital ecu , different fuel system which is several different items you would need so much stuff to turn it to efi youve never seen and with no experience its not a so easy project. i gave big big bunch of bridge port parts to Chris Carson a few years ago several horns fronts all kinds of stuff off of bridge ports think i found a external tpi while looking for my DDT chips the other day if it was me id build a 200 efi and leave the 2.4 stuff behind at this point some parts are disappearing from the market and NLA or a carb 200 which is a lot cheaper
nitro_rat liked this post
09-12-2019, 03:52 AM #48Member
- Mar 2017
- Cordova il
- 90
Thanks for the input all and certainly impressed by the wealth of knowledge on this site. I leaning more to agree with Texas here.
Anyone need a 2.4 BP block and mid section?
09-12-2019, 04:24 AM #49
post pics of mid. If its one piece plate and single ram trim, worth more than the rest of your Bridgeport stuff.
OMC Tech: 2006 115 E Tec interchangeable parts with 2000 johnson ocean pro 130
By thunder77 in forum Technical DiscussionReplies: 12Last Post: 03-20-2019, 03:01 PM -
Ton of Cross Flow Racing OMC Racing Parts
By TomAprilsswitzers in forum Outboard EnginesReplies: 10Last Post: 06-22-2016, 02:06 PM -
Are 1989 and 1987 Evinrude parts interchangeable?
By mragu in forum Technical DiscussionReplies: 1Last Post: 12-03-2008, 07:52 AM -
Interchangeable?
By play2win in forum Technical DiscussionReplies: 0Last Post: 06-11-2008, 10:27 AM -
260/280 parts interchangeable?
By STV Dreamer in forum Technical DiscussionReplies: 4Last Post: 08-04-2005, 09:21 AM
