Results 31 to 45 of 49
09-11-2019, 03:16 PM #31
09-11-2019, 03:19 PM #32
The horn motors have the injectior bosses in the front 1/2. All horn motors were 7 petal. No 5 petal front 1/2's have injector bosses. The horn should physically bolt on but there wil be nowhere to put the injectors...
There was an injected front 1/2 in the classifieds recently.
Merc 2.5 thanked for this post
09-11-2019, 03:51 PM #33Member
- Mar 2017
- Cordova il
- 90
09-11-2019, 03:52 PM #34
Thought there was something different
09-11-2019, 03:53 PM #35
That's a 5 pedal on "racing " engine. Hard to belive that's a racing 2.4. What's the serial#
09-11-2019, 03:55 PM #36Member
- Mar 2017
- Cordova il
- 90
The five pedal was from a diff engine and I was wondering if I could/should run this on the race 2.4
Number stamped on block is 91c854
09-11-2019, 03:57 PM #37
That's not serial, should b welch plug in top block in between heads or where to block halves meet where throttle timin arm goes
And yes that was a carb front halfLast edited by Merc 2.5; 09-11-2019 at 03:59 PM.
09-11-2019, 04:12 PM #38Member
- Mar 2017
- Cordova il
- 90
09-11-2019, 04:42 PM #39
With yr being 91. Is there not a plug that looks like freeze out plug on top of block? Usually letter comes 1st in serial
09-11-2019, 04:44 PM #40
Well for ****s and giggles. What's the tag on mid
09-11-2019, 04:45 PM #41Member
- Mar 2017
- Cordova il
- 90
Oc276549
09-11-2019, 04:57 PM #42
Comes as 90 2.4 carb is block black or "natural color "
Are the heads bolted on it?
03/12/91 is. Consider 90 model
09-11-2019, 05:13 PM #43Member
- Mar 2017
- Cordova il
- 90
Block is bare and heads are missing
09-11-2019, 05:21 PM #44Member
- Mar 2017
- Cordova il
- 90
09-11-2019, 06:19 PM #45
Be further ahead to build 2.5
OMC Tech: 2006 115 E Tec interchangeable parts with 2000 johnson ocean pro 130
By thunder77 in forum Technical DiscussionReplies: 12Last Post: 03-20-2019, 03:01 PM -
Ton of Cross Flow Racing OMC Racing Parts
By TomAprilsswitzers in forum Outboard EnginesReplies: 10Last Post: 06-22-2016, 02:06 PM -
Are 1989 and 1987 Evinrude parts interchangeable?
By mragu in forum Technical DiscussionReplies: 1Last Post: 12-03-2008, 07:52 AM -
Interchangeable?
By play2win in forum Technical DiscussionReplies: 0Last Post: 06-11-2008, 10:27 AM -
260/280 parts interchangeable?
By STV Dreamer in forum Technical DiscussionReplies: 4Last Post: 08-04-2005, 09:21 AM
