Page 1 of 4 1 2 3 4 LastLast
Results 1 to 15 of 49
    Mar 2017
    Cordova il
    What parts are interchangeable 90 2.4 racing vs 89. 150 xr4
    Hey all
    i picked up a blown 1990 2.4 racing merc itís missing most electronics flywheel wiring carbs, reeds and heads. So itís basically just a rotating assembly.
    was wondering if any of my 89 2.4 liter parts are interchangeable. I have mid section and lower unit for the 1990 2.4 so if some of my other parts will work on this engine I may put the money in to finish it off otherwise I am going to rebuild the rotating assembly and sell it
    Sep 2017
    Ashland city tn
    What r u wanting to change ? Mid and lower gudnfor either power head ...
    Mar 2017
    Cordova il
    I ultimately want to put the racing one back together if some of the other parts will swap
    The other 2.4 was complete engine with a scored cylinder
    i also have a complete 1990 2.5 with blown cylinder
    FYI I bought them blown up
    Sep 2017
    Ashland city tn
    R u talking bout lectrics, carbs and such? Carbs wont b no gud for racin mota, if the xr4 has the water cooled 40 amp ,I wouldnt bother using that system.
    If has 16 amp system that will swap
    Mar 2017
    Cordova il
    I do have a 16 amp charging system
    what are your with using the steel flywheel?
    Mar 2017
    Cordova il
    Will the heads fit? Or will that drop compression too much
    Sep 2017
    Ashland city tn
    Heads will fit but not sure of the cc of ea motor , would need to cc them or bolt on and do comp test ,,
    Any 9 or 16 flywheel will work , red or green I believe , they made a red 40 amp wheel to but they r alot bigger
    Mar 2017
    Cordova il
    If I bolt them on what compression should I shoot for pump gas or high octagon?
    thanks for the help
    Sep 2017
    Ashland city tn
    Added compression =more fuel/rejet also , 93 pump gas 140 145 , I shot for 145 and got got 145-150 been fine on 93
    Apr 2017
    pa
    5 Post(s)
    1990 racing 2.4? Bridgeport?
    Mar 2017
    Cordova il
    Yes 1990 2.4 Bridgeport
    also looks like intake and reed setup will bolt on from the stock engine is that advisable or should I look for the a racing setup somewhere?
  12. #12
    Apr 2017
    pa
    5 Post(s)
    What kind of damage to the block? Is the bridge broken?
  13. #13
    Mar 2017
    Cordova il
    Bridge is not broken but cylinder is scored pretty deep rod and piston are gone For That cylinder but sure looks like it may have broken a ring
  14. #14
    Jul 2002
    FT WORTH, TEXAS
    do you know if its was carb or horn? horn was a 7 petal reed mota i never had a carb bridgeport but lots of horn stuff all were 16 amp alum flywheel stuff
  15. #15
    Jul 2002
    FT WORTH, TEXAS
    James Perry can put a steel sleeve in it, dont go for the fanged sleeve it junks the block because you have to cut the sleeve holder short to accommodate the flange and its not required for the right machine shop like perry
  16. Likes bullet123 liked this post
  1. OMC Tech: 2006 115 E Tec interchangeable parts with 2000 johnson ocean pro 130
    By thunder77 in forum Technical Discussion
    Last Post: 03-20-2019, 03:01 PM
  2. Ton of Cross Flow Racing OMC Racing Parts
    By TomAprilsswitzers in forum Outboard Engines
    Last Post: 06-22-2016, 02:06 PM
  3. Are 1989 and 1987 Evinrude parts interchangeable?
    By mragu in forum Technical Discussion
    Last Post: 12-03-2008, 07:52 AM
  4. Interchangeable?
    By play2win in forum Technical Discussion
    Last Post: 06-11-2008, 10:27 AM
  5. 260/280 parts interchangeable?
    By STV Dreamer in forum Technical Discussion
    Last Post: 08-04-2005, 09:21 AM
