Results 1 to 2 of 2
    Nov 2003
    Simi Valley, SoCal
    300XS Trim pump wiring
    I posted this in tech but it probably should be here...
    I'm changing my wiring over from analog harnesses with the adapters to the Smartcraft harnesses. Where does the trim pump connect to the engine? It was connected to the adapter. A picture of the connector would be great. I'm starting to think it "Y"s of of the cowl trim switch but I can't find the part number for the harness. Also looking for a place to pick off Ignition (violet) on the engine so I don't have to run back from the dash for my low pressure fuel pumps.
    Thanks,
    Bob
    96 Cougar 23 MTR twin 300XS's. 100 something
    98 Laveycraft Sebring 20.2 Tunnel 280 90 something SOLD
    85 Baker RST 220 Laser SOLD
    Nov 2003
    Simi Valley, SoCal
    I found the connector. It was tied to the harness with a weather cap on it where the cowl switch taps in. It's a 3 pin Delphi Metri-pack 150 connector with a blue and green wires. I hope this helps someone else in the future.
    Attachment 448567
  1. 300XS trimp pump wiring
    By luv2gofast in forum Technical Discussion
    Last Post: 09-10-2019, 06:54 PM
  2. Mercury Trim Pump Brand New - 300XS Style Fast Trim
    By aggiestckl in forum Misc. Parts and Accessories
    Last Post: 10-15-2016, 07:21 PM
  3. Replies: 7
    Last Post: 12-16-2015, 05:49 PM
  4. Trim pump wiring???
    By mragu in forum Technical Discussion
    Last Post: 05-28-2015, 11:50 PM
  5. Mercury Tech: trim pump wiring?
    By david martin in forum Technical Discussion
    Last Post: 09-09-2012, 10:43 PM
