Results 16 to 26 of 26
Thread: Lith-ion debate
09-10-2019, 09:38 AM #16Team Member
- Sep 2008
- Dow, IL \ Theodosia Mo.
- 297
- 17
- 87
- 51
I would like to hear more on using only lead acid batteries. I have heard from more than one good tech that you should only use lead acid on a stator charging system.
09-10-2019, 09:44 AM #176000 RPM
- Aug 2015
- Southeast
- 1,070
- 134
- 80
- 48
- 615
Maybe call CDI and ask for their reasoning. That's who told me about it. That being said, I just bought a used boat with new CDI parts and it has a blue top Optima battery. Working fine.
STV ProComp w/ 225 Promax
STV Procomp with 280
25 Liberator "The Battleship"
Blazer 650 Pro Tour
09-10-2019, 10:01 AM #18
09-10-2019, 11:17 AM #19
Is a Bit deeper than just saying a AGM or Lipo battery cant take the Stator Charge or the Higher Charge rate. Because thats not the case at all. First one cant just go out and buy any AGM or LIPO battery and imstall it in a Boats marine charging system. The batteries have to be able to accept the charging systems system. YES most AGM and Lipo batteries take a special charger or they will get damaged. But there are AGM and LIPO batteries that will properly function without damage installed in a Marine vessel. For Example In My race Boat I was running 2 Braille B1321 batteries @ 21 lbs each at a cost of around $324.00 each. they had the following specs: Pulse Cranking Amps (PCA) 5 sec @ 80F: 1380
Pulse Cranking Amps (PCA) 10 sec @ 80F: 1207
Pulse Cranking Amps (PCA) 20 sec @ 80F: 1066
Cranking Amps 30 sec @ 80F: 892
Cranking Amps 30 sec @ 32F: 742
Cold Cranking Amps 30 sec @ 0F: 550
They went for 3 years without a glitch and I ended up selling them and 2 years later the guy is still racing with them in his boat. The key is to keep them properly charged and maintained. The Same goes for LIPOs. I wanted to loose some weight so I Bought 2 Earth X ETX 900 Lipos @ 4.5 lbs each with 860 Pulse Cranking amps and 480 CCA's. So basically I lost 32 lbs But at a cost of $1000.00 Plus a dedicated LIPO charger for another $168.00. I called earth X spoke with a Engineer told him my application and he told me the batteries I needed to maintain the factory warranty. Ive had them Three years with not the first issue. NOW!!! If one thinks they are going to put the batteries mentioned in a Bass Boat with alot of electronics and trolling motor or a River rider with a Stereo system and expect them to hold up like a Marine Deep Cycle Lead Acid battery It Aint Gonna Happen!!!Last edited by HStream1; 09-10-2019 at 11:26 AM.
09-10-2019, 11:44 AM #20Team Member
- Sep 2008
- 297
- 17
- 87
- 51
How about AGM batteries damaging stators or causing engine performance problem? Anyone with experience?
09-10-2019, 03:21 PM #21
I've been lurking around this thread since it started, waiting for the down sides to surface. I love using them in every portable tool and handheld device I own, but I'm still not putting one in my boat, motorcycle, or auto. There are many accounts of over charging causing "thermal runaway" - a condition brought about by too many volts/charge rates exceeding the specified limits. The most famous of which was the grounding of Boeing's brand new 767 a few years ago. There were dozens of homes, garages, repair shops, and marina storage facilities burned to the ground after someone used the wrong charger. While I can be sure to use the charger sold with and for the battery, I cannot always be sure it won't malfunction or that a maintenance person won't plug it into a non-compliant charger.
Boat U.S. magazine had an article on this very concern some years ago and showed a boat and it's storage building melted to the pavement by runaway Lithium Ion battery charging. I'm not saying not to - just want to say "Use Caution" and post labels letting anyone/everyone know what's underneath the decks. -- Gordon
09-10-2019, 10:42 PM #226000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
We had at least 2 lead acid fires at the marina while on a tender.
Starting In the end a properly taken taken care of lead acid will last 1-2 years on the starter. At 60-80$ in the end besides being readily available their also good advice cost wise.
Now deep cycle trolling motor and such it’s hard to beat agm Lipo
09-11-2019, 06:01 AM #23
Lithium polymer are considerably more dangerous than lithium ion. I wouldnt use a lipo battery personally. Lithium Ion I could be tempted for sure. Cant be that difficult to rig up a charge limiter or some sort of regulator that would jive with the lithium ion batteries.
09-11-2019, 08:19 AM #246000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
09-11-2019, 12:55 PM #256000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Darn now I’m mixing up lithium ion and lipo it never ends ahhh.
Naturally thats why many just go lead acid.
KIRCHNER liked this post
09-11-2019, 01:48 PM #266000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
T HEY only can create trouble if there not used properly. i talked to several manufactures, all say to follow simple guidelines. i the last 5 years, they have become much more user friendly. did you know if you look into the cells of a lead acid battery with a flashlight, it can explode. seriously.
Tis Is The REAL DEBATE
By ASPB in forum The Scream And Fly LoungeReplies: 4Last Post: 10-09-2008, 01:05 PM -
Debate this
By Hot Shot Merc in forum The Scream And Fly LoungeReplies: 31Last Post: 11-21-2004, 08:23 PM
