Results 1 to 8 of 8
09-08-2019, 12:14 PM #1Junior Member
- Apr 2007
- Brownwood, TX
- 18
1988 Hydrostream Vegas, 200 hp Mercury...for repair, damaged
SOLD! Thanks everyone. (10.1.19)
I have some unfortunate news to share. My black Vegas has gotten even blacker.
The boat was in my storage locker when the locker two doors down went up in flames. The fire never reached the Vegas , but heat, soot and ash did. The heat came from above. I had a plastic cockpit cover on the boat and it melted completely. That’s what you see on a steering wheel, the gunnels, and some of the seating.
The engine is a 200 hp, 2.4 liter Mercury from the 90s. It has a lightweight cover and low-water pick up. It probably only had about an hour on it since it had been serviced with carb cleaning, gearcase oil, and a compression check.
I haven’t started the motor as the battery is dead. However the small battery I had with me would slowly turn the motor over so I know it’s not locked up. Also, the hydraulic steering is working fine, along with the trim and tilt.
The trailer looks to be in good shape as it was before the fire. Both tires were still full of air and the grease on the hubs looks brand new.
The hull seems to have suffered no damage. It was in very good shape before as there have never even been any holes drilled in it for accessories, etc.
The rubber in the small rub rail has melted in places.
The deck received the brunt of the ash and soot. I was surprised when I took a gasoline rag and wiped it a bit to find out it’s not damaged, at least the part I wiped. However, when I looked again, days later, I found blistering, warping and even a six inch crack (picture). I gotta go with...it’s shot. Too bad....struck down with still so much potential.
The interior is, of course, ruined, however everything is there and available for patterns. The gauges and the steering wheel...ruined.
The hydraulic steering works fine, so does the trim. The factory fuel cell is fine.
Selling as is, where is. $3000.
The subject of separation will probably come up. Yes, I will separate if someone only wants boat and trailer.
I have clear Texas title for the boat, motor and trailer. These will all need to be transferred at the time the new owner takes possession.
Some of you are probably feeling a little sick to your stomach right now and I appreciate the sympathy pains.
As for myself, I think I’m doing well. I'll live to boat again. $3000,00Last edited by Surface Scratcher; 10-03-2019 at 07:33 AM.
09-08-2019, 04:45 PM #2
I know the feeling ,it does suck all I can say ,any insurance?
09-09-2019, 01:54 PM #3
That's terrible....
Laseraddict liked this post
09-11-2019, 07:32 PM #4
PM sent.... sorry if this is a duplicate.
10-01-2019, 12:39 PM #5Junior Member
- Apr 2007
- Brownwood, TX
- 18
Well, I got it sold to a gentleman who has experience with fiberglass and fast boats. Hopefully he will save it.
02-19-2021, 07:58 PM #6Member
- Apr 2018
- Mid west
- 34
- 46
- 498
Just curious what that T fitting with the thin metal line running over top of the engine towards the rear of the powerhead?
Thanks
25two.stroke thanked for this post
02-19-2021, 09:39 PM #75000 RPM
- Sep 2008
- charlestown, ri
- 293
- 10
- 37
i wonder if wet-sanding and a clear cote would take care of most of it. accept the interior detailed parts. lots of work either way. glad its off to a good home!
02-22-2021, 10:46 AM #8Junior Member
- Apr 2007
- Brownwood, TX
- 18
Laseraddict thanked for this post
1988 Hydrostream Vegas XT with 2.4 200 HP Merc. and Shorelander trailer
By 67dartman in forum Hulls up to 20'Replies: 1Last Post: 05-04-2019, 06:31 PM -
1988 Hydrostream V-King YT w/Mercury XR6 150 and Trailer- $6,500
By seangjohnson in forum Hulls up to 20'Replies: 4Last Post: 05-09-2015, 05:25 PM -
1988 Hydrostream Vegas Project
By oceanoutboard in forum General Boating DiscussionReplies: 16Last Post: 11-05-2007, 09:03 PM -
By oceanoutboard in forum Props, Setup, and RiggingReplies: 1Last Post: 10-12-2007, 01:38 PM -
By oceanoutboard in forum Technical DiscussionReplies: 0Last Post: 10-12-2007, 08:34 AM
