Results 1 to 3 of 3
Thread: Need prop help
09-07-2019, 08:11 AM #15000 RPM
- Mar 2011
- La.
- 106
Need prop help
Guys, I need a little help with propping my boat.
I'm running a 2004 Bullet 21XDC hull with a 2011 ProXS running a 32p Bravo 1 prop. It's very sluggish coming out the hole not allowing the engine to turn up until it brake over onto plane. I know I need to drop the pitch but should I drop a blade as well? I have tried a 31p Bravo 1 and it's about the same, top end is only 70mph at 5450 to 5500rpm very light load, driver with full fuel. Any good suggestion will be appreciated, shouldn't I be turning 5800 to 6400rpm with this motor? I was thinking about trying a 27p Tempest just don't know if that would be to much of a drop do to dropping a blade as well.
Also one other thing, when I put it into reverse with both Bravo props the motor wont turn up much ether. Just a side note, could something be wrong with the motor?
09-07-2019, 01:16 PM #2Member
- Oct 2017
- Ontario
- 37
- 16
Try a 28-30p Mercury ProMax with PVS holes. 14.5 instead of 15.25. Pretty much a thick Pro ET!!
Try the Trophy you mentioned.....Sometimes they work amazing on the strangest things!!
Hot Rod liked this post
09-07-2019, 07:24 PM #3Screaming And Flying!
- Sep 2001
- shreveport,la
- 5,706
- 118
- 85
- 773
F1 / F2 Racing Items for Sale!! Dewald props, Performance Prop, Prop test wheel...
By Spectre Powerboats in forum Misc. Parts and AccessoriesReplies: 1Last Post: 02-20-2018, 03:01 PM -
Is there any difference in the engine on a dual prop vs Single prop Yamaha vmax 150 ?
By jlinmo226068 in forum Technical DiscussionReplies: 1Last Post: 02-03-2018, 02:08 PM -
OMC Tech: Help! 225 carbed Johnson melting prop hubs / high exaust temps through prop hub
By Tunnelvision1995 in forum Technical DiscussionReplies: 7Last Post: 09-12-2017, 08:03 PM
