Results 1 to 13 of 13
09-05-2019, 09:49 PM #1Team Member
- May 2009
- 1,883
- 558
- 77
- 637
- 308
- 6 Post(s)
90’s 9.9 with plastic top and bowl carb?
So I have this 1990’ish Evinrude 9.9 that I bought almost brand new at an estate sale for next to nothing. It fired right up and ran great. But then I let it sit for ten years without even draining the carb. So today I finally got to it and pulled the carb. And of course, just like on my 1993 115, it has the black plastic float bowl AND black plastic top cover (with the mixture knob). Now before I clean it up and rebuild it with a new kit, I don’t want to waste my time if the plastic top and bottom are likely to be warped (like the plastic float bowls were on my ‘93 115).
I know they made this motor for a long time. Should I be using a different year carb? I’m not obsessed with getting a 15hp carb, but not against it either. I just want to get back in business. Who would you seek out to buy one of these?
-Peter"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
and a handful of clunkers
09-06-2019, 08:25 AM #25000 RPM
- Feb 2009
- Dunnellon, Fl. / Cincinnati, Oh
- 419
- 62
- 28
- 136
- 162
Plastic bowls can usually be trued up with a flat surface and 320 grit paper.
Worked on my gt150 a few years back.
As long as you don't have to sand into the gasket sealing ridge,
A new gasket, don't overtighten, should be o.k.
pcrussell50 thanked for this postpcrussell50 liked this post
09-06-2019, 08:27 AM #35000 RPM
- Jan 2008
- SUMMERVILLE S.C.
- 201
- 34
- 42
the bowls on these usually don't go bad...the top cover sometimes cracks around the air needle...everything is still available if it needs replaced...IMO they are the best running ,of the 9.9/15 carbs ...the cover # may have been obsoleted, but BRP has a # for a kit with gaskets and needle....
09-06-2019, 08:44 AM #45000 RPM
- Feb 2009
- 419
- 62
- 28
- 136
- 162
Getting ready to do this 15hp. Same setup. No worries bout the plastic.
Picked this up yesterday, let's just say it was "not as advertised"
Guy ended up giving it to me for free!!!
Full of mouse nests, it's stinking up the garage.
Crystalized mouse piss all over it.
No chewed wires that I can see.
Yuck. At least it's not all salted up.Last edited by rochelle howell; 09-06-2019 at 08:53 AM.
09-10-2019, 08:59 PM #5
Capt.Insane-o, MattGreen liked this post
09-10-2019, 10:57 PM #65000 RPM
- Feb 2009
- 419
- 62
- 28
- 136
- 162
09-10-2019, 11:07 PM #75000 RPM
- Feb 2009
- 419
- 62
- 28
- 136
- 162
05-06-2020, 07:21 PM #8Team Member
- May 2009
- 1,883
- 558
- 77
- 637
- 308
- 6 Post(s)
BTW, can I use carb cleaner on the plastic idle mixture top cover? The one that houses the needle valve?
__________
the wet:
the dry:
2003 bmw ///M5
05-07-2020, 08:24 AM #96000 RPM
- Calgary, Alberta
- 1,123
- 21
- 58
- 341
- 174
You can soak the parts in OMC/BRP Engine Tuner to clean everything - it’s fantastic for cleaning “green goo” from stale fuel, takes under an hour. Used it a ton on OMC plastic carb parts, never a problem.
Matt
05-07-2020, 08:36 AM #10
I was told never use carb cleaner on plastic..
But like Matt said the tuner soaking works greatLETS GO BRANDON.... LETS GO BRANDON
'84 Checkmate Convincor
05-07-2020, 11:15 AM #11Team Member
- May 2009
- 1,883
- 558
- 77
- 637
- 308
- 6 Post(s)
Where can you buy engine tuner or mercury power tune in useful quantities for a reasonable price? I see a single spray can of OMC on Amazon for $22. Obviously that is not going to cut it.
__________
the wet:
the dry:
2003 bmw ///M5
05-07-2020, 11:39 AM #12
Should only be like $10?
Seafoam works too also... Forget name will look up the other thought I had a can in garageLETS GO BRANDON.... LETS GO BRANDON
05-08-2020, 10:46 AM #13Team Member
- May 2009
- 1,883
- 558
- 77
- 637
- 308
- 6 Post(s)
Ok got it soaking in Seafoam. Carb isn't that dirty and no varnish so maybe it's not a tough test for the Seafoam?
These elastomeric Evinrude gaskets look re usable. Are they? The carb kit I got has new ones though.
__________
the wet:
the dry:
2003 bmw ///M5
OMC plastic carb idle jets
By rude tim in forum Parts WantedReplies: 1Last Post: 07-15-2019, 12:32 AM -
Mercury TC3A Carb bowl gaskets
By Tom Smyth in forum Outboard and Racing HistoryReplies: 1Last Post: 01-06-2016, 12:34 PM -
2.4 bridgeport carb does it have a fuel bowl vent
By Cal 47 in forum Technical DiscussionReplies: 0Last Post: 03-11-2015, 03:49 PM
