Results 1 to 15 of 24
    Dec 2001
    ammmazzing......the boat is flxing..... the mount is stable......
  3. Likes Scream And Fly liked this post
    I was also very impressed with that Porta Bracket. I really never had a close-up look at one of these at those speeds until now.
    I have mounted a lot of porta's brackets. Some are over 15 yrs old now. Never needed the warranty. They're that good.....
    Sep 2012
    Just curious with the porta bracket....when lower and raising the bracket, the setback changes. Does that have an effect on the handling and balance of the boat? Or does the couple of inches not make a difference?
    You articulate the bracket to the amount of setback you want, and then bolt it to the boat at the desired height you want your engine to be, or where the boats transom allows it to be mounted. I normally adj. for full setback and bolt the bracket for the correct prop shaft dimension. The porta's allow for a lot of tuning. You do get some change in boat attitude, but you control it if you set it up correctly. I have a 26'' porta on my 26' boat and it is incredible the amount of ride attitude I can change with it. The lower plate acts as a giant trim tab. But I can also raise the prop above the keel of my boat for shallow water operation. For normal hi speed operation I have full set back.
    Sep 2012
    Ok...I got it. After looking at the video again I see the dynamics.
  9. #8
    FLA
    On the short 8" Porta Race like I have on my DW 28 the setback change is very very small . Motor never moves around like the Bobs .
    24 Twister
  10. #9
    Daytona Fl.
    7 Post(s)
    The difference in setback on the 8" is less than 1/2". I try to set it up so that the optimum height is in the niddle where the setback is the most. Strongest bracket you will ever find. 10 bolts to the transom instead of the normal 4.
    Boat Delivery available
    Things owned. NOTHING!!
  11. Thanks Scream And Fly thanked for this post
    Dec 2001
    super clean work.....dmmmmnnn....
    Jul 2004
    Connecticut
    Quote Originally Posted by WILDMAN View Post
    ...............Strongest bracket you will ever find. 10 bolts to the transom instead of the normal 4.
    10 bolts = industrial strength
  14. #12
    8 Post(s)
    could you run a ports on an offshore boat?
  15. #13
    There are a bunch of them out there.
    FLA
    These Porta are on DW 28 . He know makes a Short 8 inch to 12 inch Race version .He has made twin and triple engine brackets for race boats for years . Have seen 3 on 1 plate on 33 powerplay race boat years ago.
    Attached Thumbnails Attached Thumbnails 20190821_151428.jpg   20190728_194003.jpg
    24 Twister
  17. Likes tux974 liked this post
  18. #15
    May 2009
    Ormond Beach, Florida
    Has anyone rigged a height gauge to the Porta Bracket?
    Mark
  1. New article on the 450R posted
    Last Post: 08-14-2019, 07:11 PM
  2. Big news !!! Getting my first 450r next week!
    By WILDMAN in forum General Boating Discussion
    Last Post: 08-07-2019, 10:11 PM
  3. Bernico VC35 450R
    By AZMIDLYF in forum General Boating Discussion
    Last Post: 07-21-2019, 07:20 PM
  4. Merc 450R
    By Toffen in forum General Boating Discussion
    Last Post: 05-22-2019, 06:29 PM
  5. 450r/500r
    By Rayzor in forum General Boating Discussion
    Last Post: 08-05-2018, 08:11 AM
