Results 1 to 15 of 19
Thread: Bad switch box?
09-04-2019, 07:04 PM #15000 RPM
- Sep 2006
- 456
- 160
- 9
- 43
- 49
Bad switch box?
91 200 efi analog box(isgood) Rebuilt first lake test. Timing set at -4 * at idle and 22 at wot. Compression 124/125 across the board. 93 octane. Boat idles fine but can't get on plane . Heard a bit of detonation. Falls flat on its face between 2&3000wont rev until prop cavitates. I am suspecting a bad switch box. At what rpm does a bad switch box show itself?
09-04-2019, 09:13 PM #2
'bout there.
To fish or not to fish? What a STUPID question.
09-05-2019, 04:16 AM #3
Could be stator
Glasstream15 liked this post
09-05-2019, 06:49 PM #45000 RPM
- Sep 2006
- 456
- 160
- 9
- 43
- 49
All stator test numbers came in spec but over 3000 it drops the 2/4/6 side. Will try new stator tomorrow. Can one side of the high side of a stator go bad?
09-05-2019, 07:36 PM #5
Yeah. Sounds like high side took a sh it
Forkin' Crazy liked this post
09-05-2019, 07:46 PM #66000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Does it rev without a load?
if it does it could be fuel side, occasionally the injection is controlled by separate things at different rpm that’s also the sweet spot for that malfunction.
But its it’s more likely the stator switchbox
09-05-2019, 11:28 PM #7Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,831
- 405
- 3032
- 5318
Having pyros and indexing your fly wheel would be a great help to diagnose the problem.
09-07-2019, 08:56 AM #8To fish or not to fish? What a STUPID question.
09-07-2019, 09:00 AM #9
I agree
09-07-2019, 12:36 PM #10
Swap boxes around and c if it happens on 1,3&5
JR IN JAX liked this post
09-07-2019, 02:59 PM #11
Maybe easier to just swap stator wires to the switchboxes.
09-07-2019, 03:22 PM #12
09-07-2019, 03:49 PM #13Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
What about the regulators? Can they not mess up the stator? I believe a test is to disconnect them one at a time and test run...(Yellow wires)
09-07-2019, 06:58 PM #14
Have you run a spark check? All 6 at 7/16"? Other wise bad stator.
09-08-2019, 03:09 AM #156000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
The rev with cold start is just an old ear test and friction check. If it revs but drops cylinders start with switch box and it’s probably not fuel. Doesn’t really prove one thing or another but will show component fail is not load related.
Wring up a jack plate switch, use the trim/tilt switch?
By leaky in forum Props, Setup, and RiggingReplies: 5Last Post: 03-27-2015, 07:02 PM -
Teleflex Pro Trim Switch replacement parts (switch)
By Mike Nass in forum General Boating DiscussionReplies: 10Last Post: 01-11-2015, 07:58 PM -
switch box??
By 81hydrostream in forum Technical DiscussionReplies: 0Last Post: 02-18-2005, 08:47 PM
