Results 1 to 4 of 4
    Aug 2018
    Arkansas
    Can a prop have too much “grip” in a turn?
    Hey all,
    So my set up is a bit different than a lot of the go fast boats on this forum. I have a 753 Edge Diamondback with a slightly modified 2 stroke Yamaha 50 tiller. I’ve been playing with props and set up for the last 8 months or so trying to get the hop out of it when I took a turn.
    My current favorite prop is a 15p Powertech SRD. I have a hydraulic jack plate and have it set at 3 inches roughly. I’ve been playing with drilling vent holes to increase the holeshot. My boat likes the 11.25in diameter. My motor on take off does not .
    I have found the sweet spot. 3-4 degrees of positive trim once on step. 3 inches on the plate. 10in of setback. Once the boat breaks over the hump on getting out of the hole she’s off like a bat out of hell. Stable. Hull lifts appropriately from what I can tell from the performance. Waterline is behind the back bench. Can finally take sharp corners running a creek wide open and not almost get thrown from the boat.
    My question is this: Can prop slip HELP a boat turn smoothly? The ONLY way I’ve been able to get this boat to turn smooth and tight at WOT is to introduce what I’m assuming is aeration with the prop aka slip. I don’t lower the plate. I don’t really have to lower the trim. Just make a smooth transition into the turn, the prop “slips”, exit the turn, and prop hooks back up. Momentum is maintained through the corner. But, that goes against everything I’ve read about getting boats to corner well.
    Im thinking about having the prop worked aka more cup added, but if it’s going to hurt the ability for this prop to turn, it will do more harm than good. Thoughts?
    Jun 2018
    Floating around
    Search outboard museum on YouTube and look what Lee has to say about his five hundred dollar, per blade prior and what it does. Interesting watch
    Aug 2018
    Arkansas
    Is that the channel name? I’ll do some digging after work.
    Jun 2018
    Floating around
    Here ya go, very interesting watch and theres some prop talk in the middle that I had never heard about before. This man and his peers are the legends around here
  1. 2000 200efi wont turn over 5500rpm any size prop
    By BigKiddd in forum Technical Discussion
    Last Post: 09-02-2017, 02:57 PM
  2. How much more prop will a 2.5 turn
    By mastertrax in forum Props, Setup, and Rigging
    Last Post: 12-19-2011, 11:01 PM
  3. Mercury Tech: How can I tell what gear ratio I have? Prop turns 1/2 turn per full turn of flywheel
    By phaster in forum Technical Discussion
    Last Post: 07-20-2010, 06:36 PM
  4. Turn,Turn Turn Lady Hustler Ejected By www.freezeframevideo.net
    Last Post: 03-26-2010, 07:32 PM
  5. Turn,Turn,Turn Lady Hustler Ejected video by Freeze Frame
    Last Post: 03-24-2010, 05:04 AM
