Results 1 to 12 of 12
Thread: Tan/black port temp sensor wire?
09-01-2019, 11:43 AM #1Junior Member
- Feb 2019
- Shawnee Kansas
- 26
I’ve been working on a 92 Bridgeport EFI engine trying to get it to idle smooth,
And there is a black and tan wire coming off of the Portside temperature sensor that goes nowhere… Can someone please tell me where this wire goes… It has a male bullet connector.... thanks in advance! Kerry
09-01-2019, 12:17 PM #2
Sender for the temp gauge.
09-01-2019, 01:17 PM #3Junior Member
- Feb 2019
- Shawnee Kansas
- 26
Does it tie into the computer? Or wiring harness?
09-01-2019, 01:33 PM #4
Wire harness, should be a wire same color coming out of the 8 pin connector on the boat side.
09-01-2019, 03:12 PM #5Junior Member
- Feb 2019
- Shawnee Kansas
- 26
Will it help the engine to run leaner at an idle? Thanks
09-01-2019, 03:27 PM #6
No just for a temp gauge.
09-01-2019, 03:46 PM #7Junior Member
- Feb 2019
- Shawnee Kansas
- 26
Ok, thanks for your help!!!
09-02-2019, 01:10 PM #8
I think maybe the tan/black off port side is a temp sensor that goes to the ecu and tps and the starboard is the temp switch. If I am correct it will make a difference in idle at temp. Your tps could also be causing a rich condition. Set it at .25 volts.
RockTeam Junk
09-02-2019, 01:49 PM #91980 Cougar 19 tunnel,90 2.4L Bridgeport EFI in middle of restoration.
rock thanked for this post
09-02-2019, 02:44 PM #10Junior Member
- Feb 2019
- Shawnee Kansas
- 26
Yes, Dave is correct....
old analogue vacuum tps... I think I’m going to try some new reeds and maybe a Rapair manual tps..
any thoughts on those?
Ive got this motor on my old STV pro comp ski... running good once it’s on plane..... thanks again!
09-02-2019, 03:57 PM #11
You would think I might have considered that considering I am also old technology.
RockTeam Junk
Dave Strong liked this post
01-09-2020, 04:34 PM #126000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
tan/ blue temp gauge. tan/ black efi sensor
Mercury Tech: 2.5 / 280 Air Temperature Sensor wire question?
By fastkat101 in forum Technical DiscussionReplies: 3Last Post: 06-30-2016, 06:18 PM -
Mercury Tech: 300x Analog Temp Sensor Wire
By Liberator*21 in forum Technical DiscussionReplies: 1Last Post: 04-03-2011, 06:20 AM -
Temp sensor for OMC - water or head temp?
By STV_Keith in forum Technical DiscussionReplies: 6Last Post: 06-12-2006, 11:45 PM
