Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
    Nov 2019
    Canada
    Quote Originally Posted by Bigtbasser View Post
    Idled 2003, 225 Opti, 280 hrs, for 30 mins in order to get the Stabil throughout the system for winter. Changed spark plugs and decided to run again. I notices a slight stumble, miss. I'm thinking an injector got a little clogged. I doubt it is due to the new plugs because it was intermittent. First time doing this on hose hookup. In the past always added the Stabil on our last fishing trip. Ran compression test and all good. Been reading about adding Seafoam to VST for 5 mins, shut down let soak and run again. What are your thoughts? Second question, I have the original metal reeds. Been reading about the carbon reeds and everyone thinks they are a big improvement. Should this be a winter project or if it ain't broke don't fix it. Thanks
    Big T, although that treatment may help your motor some its not a complete fix. Your best bet is to have a full injector service and not risk having engine damage.
    www.InjectorService.com
    Call/Text - 204-326-0390
  2. Likes RSWORDS liked this post
  3. #17
    Remember that the opti's have rubber parts in the fuel rails. I did this shock treatment once and immediately had the diaphrams fail. Skip the risk and mix the recommended ratio of cleaners in the gas only. These diaphrams are 130 bucks each. About the same as injector cleaning.
    Nov 2019
    Canada
    Depending what you want you can have as much or as little done to the system on the Optis as you want. We do injector cleaning, but if your concern is the entire fuel system we can clean that as well. We take the rails completely apart, inspect the diaphragms & springs. Then we ultrasonically clean the fuel rails WHILE pumping fluid through the rails. This cleans and flushes everything out. The fluid that is recirculated through is filtered at 2 microns before going though.
    Like XstreamViking said, its not worth risking putting something that is not an approved cleaner or treating stronger than recommended. There is a lot more going on in these motors than in a typical fuel injection system, and even then its not the correct way of going about it.
  5. Likes Kcraft liked this post
  1. Mercury Tech: Quickleen in a 280
    By BagMan in forum Technical Discussion
    Last Post: 10-29-2009, 08:05 PM
  2. Shot peen?, heat treat?, cryo treat?, coat?...
    By David_L6 in forum Technical Discussion
    Last Post: 11-18-2004, 11:06 PM
  3. Quickleen
    By gaineso in forum Technical Discussion
    Last Post: 05-10-2003, 06:00 AM
  4. Do I need to use Quickleen?
    By gw204 in forum Technical Discussion
    Last Post: 05-07-2003, 04:37 PM
  5. Quickleen
    By bucket in forum Technical Discussion
    Last Post: 10-03-2002, 05:29 PM
