Results 1 to 15 of 18
08-31-2019, 06:29 PM #1
shok treat with quickleen added to VST reservoir?
merc 250XS with sever case of dirty injectors..heard from reliable source this works,just wonder what ratio or how heavy dose I can pour in VST (and still run)?thanks
"Whacker Smacker" #561 IHBA M/E div1 2007& 2006 first looser champion
2007 Sportsmen Driver of the Year
08-31-2019, 06:43 PM #2
I do it at the end of the year. It works best when it sits for a bit. I mix a bottle with just under a gallon of fuel in a can and run the motor several times on the hose over a period of a few days. I also leave that concoction sit in there during the off season. Actually I would buy a can of Mercury power tune and use that instead.
Chillinthemost thanked for this post
08-31-2019, 08:13 PM #36000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
As a yearly thing 100% it will help keep injectors clean. If your injectors are truly dirty though (to the point of sever run issues) nothing in a bottle will fix them.
And it they are that bad what's the VST look like?.....Last edited by RSWORDS; 08-31-2019 at 08:16 PM.
08-31-2019, 08:30 PM #4
thanks,this is my first go at troubleshoot/repair an airpump motor..2,5 drags I can do in my sleep.trying to help close friend
09-01-2019, 11:21 AM #55000 RPM
- May 2016
- keys
- 795
- 31
- 45
- 254
- 424
+1 for power tune. Clean the vst out first then empty the whole can into the vst. If the injectors are truly dirty from trash and debris, as stated above nothing in a can will help. But if it's just varnish then the power tune should clear it out. Also spray some slowly into the compressor intake with engine running
09-01-2019, 01:35 PM #66000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Try some pea based direct injection cleaner works great on the di tips and fuel injectors. This di it help to know what tip is dirty.
I would also also buy a can of Sunoco or vp straight gas to mix with not the pump gas. As clean quality gas cleans just as good as the detergents.
09-02-2019, 10:09 PM #7
09-03-2019, 09:46 PM #85000 RPM
- Apr 2017
- Pomona ny
- 251
- 12
- 48
I would definitely send them out to get flow tested and cleaned youd be suprised how much carbon builds on the air injectors. This was after a year and half and not many hours. Live up north so boating season is rather short. I would of expected a performance loss with an injector looking like that but the only reason i got them cleaned this particular time is because my compressor went kaboom. Before that happemed the motor was running top notch. I run a 250xs also
stoker2001 liked this post
09-03-2019, 10:33 PM #9
09-04-2019, 08:26 PM #105000 RPM
- Apr 2017
- Pomona ny
- 251
- 12
- 48
Around 530 when it went which based on my research around 500 is when the 1st Gen adonixed compressors go. Meant to change it out before hand but put off due to the cost which ended up costing me more by waiting of course. The newer all black compressors (dual bearings) has a much longer lifespan, haven't read about any failures.
09-05-2019, 10:20 AM #11Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
09-05-2019, 01:36 PM #125000 RPM
- May 2016
- keys
- 795
- 31
- 45
- 254
- 424
XstreamVking thanked for this post
09-06-2019, 04:31 PM #136000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
The pea is a chevron invention works better then all the alcohol and transmission fluid based cleaners.
Its in chevron techron, ansoil pi, redline something, royal purple max atomizer,
i run the royal purple it even cleans the black out of the prop sometimes.
Like any cleaner though results my vary
11-17-2019, 10:02 PM #14
Personally I think if your using cleaners in a bottle for anything other than routine maintenance purposes you should probably consider having your fuel and air injectors cleaned and flow tested.
RSWORDS liked this post
11-21-2019, 07:35 PM #15New Member
- Nov 2019
- eagle idahi
Idled 2003, 225 Opti, 280 hrs, for 30 mins in order to get the Stabil throughout the system for winter. Changed spark plugs and decided to run again. I notices a slight stumble, miss. I'm thinking an injector got a little clogged. I doubt it is due to the new plugs because it was intermittent. First time doing this on hose hookup. In the past always added the Stabil on our last fishing trip. Ran compression test and all good. Been reading about adding Seafoam to VST for 5 mins, shut down let soak and run again. What are your thoughts? Second question, I have the original metal reeds. Been reading about the carbon reeds and everyone thinks they are a big improvement. Should this be a winter project or if it ain't broke don't fix it. Thanks
Mercury Tech: Quickleen in a 280
By BagMan in forum Technical DiscussionReplies: 13Last Post: 10-29-2009, 08:05 PM -
Shot peen?, heat treat?, cryo treat?, coat?...
By David_L6 in forum Technical DiscussionReplies: 44Last Post: 11-18-2004, 11:06 PM -
Quickleen
By gaineso in forum Technical DiscussionReplies: 5Last Post: 05-10-2003, 06:00 AM -
Do I need to use Quickleen?
By gw204 in forum Technical DiscussionReplies: 1Last Post: 05-07-2003, 04:37 PM -
Quickleen
By bucket in forum Technical DiscussionReplies: 2Last Post: 10-03-2002, 05:29 PM
