Results 1 to 15 of 56
Thread: Crossflow build
08-30-2019, 12:25 PM #1Junior Member
- Aug 2019
- Canada
- 24
Crossflow build
Hi all, been browsing the forum and seen lots of great info, wondering if someone could lend some advice.
Boat is a 15.5ft hydrasport veestar 90, does have a pad.
Current engine is a '87 Johnson 88. I also have a '73 Evinrude 115 and '76 Evinrude 135 (no lower or power pack on 135).
Want more ponies out of the 88, one cylinder is a bit low so was going to open it up anyway. Not sure of the condition of the 135 block but options right now are to port the 88 using the 135 specs, or swap power heads if the 135 is usable.
What would my best options be with the parts I have? Anyone have porting measurements? Don't want a full 9 page motor but a lake runner that could ideally get me to 60mph+ at 6000rpm.
08-30-2019, 06:29 PM #2Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
the powerhead wont bolt up due to 2 of the front studs being in a different place
the 135 has great heads but you will need good fuel
08-30-2019, 06:33 PM #3Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Best Bet.... save ya self lots of work.....get a V6 150 merc ....Cheep .... common..... and ya can get parts for them....And they will blow the old stuff ya have out of the water.....I see ya up North.....and things may be harder to find....go for a ride....JMO........
TNRoostertail liked this post
08-30-2019, 07:03 PM #4Junior Member
- Aug 2019
- Canada
- 24
Thanks. I've been doing a ton of research and always find conflicting info. For example 115 and 135 crossflow have the same porting (different heads/exhaust/etc). My 88 is the old 115 since it's post prop rated hp. Guess I won't know until I open them up. Plan is to run 91oct.
Plan so far
-use 135 heads, carbs, bubble exhaust on 88.
-port and widen with 5/8 corners the 88 to the 135 specs
-keep the 88 coils
-throw a 23p prop on and see what it does after getting Jetting dialed.
Any better way to do it with what I have? Is dropping the bottom of the exhaust port advisable, such as in the 9 pages?
Boat parts are scarce here. Also a v6 Merc would weigh almost 100lbs more then the 88. I'm keeping this on a diet, also thought about a looper but similar weight penalty.
08-30-2019, 07:04 PM #5Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Looper 140, then start the game.
AZMIDLYF liked this post
08-30-2019, 07:19 PM #6Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
keefallan liked this post
08-30-2019, 07:27 PM #7Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
I'll take your word for it but thought less by enough.
So a looper v4 is about a hundred more than an X flow?
Wow , big bore with big lu 368. Must have been thinking earlier version.Last edited by FMP; 08-30-2019 at 07:48 PM.
08-30-2019, 08:02 PM #8Junior Member
- Aug 2019
- Canada
- 24
I originally was thinking 140 looper if I could find one until I found out how heavy it was. I'm thinking if an old 90hp can push it low 50s, a massaged 135(130ish prop) could be in the 60s setup right. Not to mention higher cruising speed which would be used often heading to fishing spots.
08-30-2019, 08:28 PM #9
Will hedrick thanked for this post
08-30-2019, 08:46 PM #10
Find a 79 or newer 140 and build a drop on. Keep the 88 for a spare for when you blow it up.
79 up has the same linkage. 78 down no.
In 87 they started rating HP at the prop instead of the flywheel. So you really have a low compression 115 or 100. I think the 87 up 115s were the old 140 with looser heads.
Some one will be along in a minute to tell me how wrong I am or agree with me, one or the other!!! LMAO!!!
The heads in 79 and 80 will probably be good enough. Premium fuel ONLY!!! I am more of a V6 Xflow guy. But I assume they were like that because right after 80 on the V6s they started loosening the heads or adding thicker head gaskets because of the crappy gas. No one wanted to pay for premium.
mrichartz liked this post
08-30-2019, 09:57 PM #11Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Chrysler ! Ha!!! Didn't expect that, did you!
08-30-2019, 10:01 PM #126000 RPM
- Calgary, Alberta
- 1,123
- 21
- 58
- 341
- 174
Please update your location so Canadian S&F members can perhaps help more. Crossflow V4 parts are plentiful in Canada if you look in the right places.
The 135 heads are the tightest non-race V4 heads available and will work great if you use enough octane but I caution that 91 with proper timing is probably NOT enough; try Sunoco or Chevron 93/94.
To to make the ‘88 work well you actually need the bubble-back exhaust housing from the old 140s/later 115s. The turtle-back 135 is not the same. Overall Forkin is pointing you in the right direction.
Matt
08-30-2019, 10:08 PM #13Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
I would think fresh 91 Shell will do the job with lots of good oil and proper tuning.
08-31-2019, 01:05 AM #14Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
I saw a 140 bubbaback in the scrappy yard.....too lazy to pull it out.......
08-31-2019, 08:26 AM #15Junior Member
- Aug 2019
- Canada
- 24
Thanks for the info guys, been scouring the net enough to make my head spin.
I'm from southern MB. I'll keep my eyes open for an old 140 but will also buy a lottery ticket. Im all for someone nearby that has stuff laying around!
Can I adapt the 135 carbs on the 88? As in swap the carbs but use the newer linkage system from the 88? Was hoping the ports wouldn't be to far off the 135 and use the 135 exhaust. I read it's not as good as the 140(smaller channels?) but still could be used? Thanks again for the help!
"Good" V4 crossflow build
By hq_ in forum Technical DiscussionReplies: 34Last Post: 02-09-2018, 01:38 PM -
Best workstand to build powerheads? Build? Buy?
By Zoomba in forum Technical DiscussionReplies: 6Last Post: 03-10-2014, 07:45 PM -
OMC Tech: v6 crossflow interchange with v4 crossflow midsection and driveshaft?
By 200valeroyt in forum Technical DiscussionReplies: 17Last Post: 09-14-2011, 12:09 PM -
OMC Tech: 150 Crossflow VS 150GT Crossflow
By LSaupe in forum Technical DiscussionReplies: 4Last Post: 11-06-2010, 10:03 AM -
Build better and Safer Build Union
By SnakeBit in forum The Scream And Fly LoungeReplies: 38Last Post: 09-06-2008, 05:00 PM
