Results 1 to 2 of 2
    Feb 2007
    Western Washington State
    Trim Motor Going Bad?
    I have a 3-ram trim on my '87 Merc outboard, that was actually taken from a Mariner (so it's grey), and it appears to have an after-market trim motor on it because the trim motor is a round ARCO unit. I'm posting here because the "up" trim is now starting to work intermittently. Juice is getting the "up" relay because when I hit the rocker switch at the control box I can hear the circuit close, but the motor doesn't engage. I checked all the wiring under the cowl and nothing is burnt or loose. Also, I've noticed that the motor isn't running evenly anymore. The RPM of the spin varies a bit and sounds kind of raspy. Is my motor going bad?
    Oct 2018
    Flint River GA
    When it stops try tapping on the motor with the handle of a screwdriver while holding the switch. If it starts working its the motor. These motors have brushes that can stick. Had the same issue with mine. I bit the bullet & bought an oem replacement from Merc but when I took it out of the box first thing I saw was a dang made in China sticker! Not sure which would be better, after market or Merc. The oem def costs more. RR
  1. 2.5 trim motor
    By outasite in forum Misc. Parts and Accessories
    Last Post: 03-20-2016, 10:28 AM
  2. 40w motor oil in Power trim motor
    By LaredoModV in forum Technical Discussion
    Last Post: 04-21-2006, 10:08 PM
  3. trim motor
    By woody in forum Technical Discussion
    Last Post: 07-04-2002, 11:24 AM
