Results 1 to 3 of 3
Thread: 97 Gambler 209
    Mar 2016
    St. Cloud Florida
    97 Gambler 209
    I have a 97 Gambler 209 w/ an 01 3liter 225efi and I知 getting 72ish with a light load and 5500 rpms WOT spinning a 3blade 25 fury. I知 wanting to lighten the load on the transom with a 2.5 motor and be able to spin a larger prop. My question is what 2.5 motor would be a good starting block to build as well as what mods? Any help is appreciated.
    Sep 2017
    Ashland city tn
    Is the 3L wore out? I would think u can spin bigger prop with the torque of the 3L. U got pics how it rest n water?
    Mar 2016
    St. Cloud Florida
    The back end sits noticeably lower after the motor was swapped from a stock 2.4 (blown) to the current 3liter. Compression tests consistently come back at 110-115 across the board. I did hit 74 with a 27p trophy but only turned 4500rpms. The motor is also slow to spool up when taking off. I will post pics of it in the water as soon as I can get her in the water. I was thinking a modestly built 2.5 would provide faster response when taking off, more RPM’s, and less weight.
  1. Gambler
    By shearwater1 in forum Ebay Listings and Other Internet Listings
    Last Post: 07-20-2019, 06:19 PM
  2. Gambler
    By fast gambler in forum Hulls larger than 20'
    Last Post: 09-23-2016, 02:20 PM
  3. Gambler
    By fast gambler in forum Hulls up to 20'
    Last Post: 05-28-2016, 02:47 PM
  4. help on gambler set up
    By bhasty in forum General Boating Discussion
    Last Post: 12-19-2013, 09:24 PM
  5. gambler set up ?s
    By fast gambler in forum Props, Setup, and Rigging
    Last Post: 03-10-2008, 11:55 AM
