Results 1 to 3 of 3
08-25-2019, 07:14 PM #15000 RPM
- Aug 2019
- Palmharbor
- 557
- 20
- 58
- 150
Best way to turn up a 3.3 ltr Evinrude
Can do the DBR pistons V8 rods sleeves block work questions
longivity #1 usable power 3500 cruse, do I ditch the stock Ecu and use doner ocean pro carbs an electronics with a 8500 rpm cdi or go with a motec ecu a have it programmed as a do or as one of my old school wrencher said to use a yami comp an modify the front half for injectors ad a oxygen sensor in exhaust adaptor an let it rip it will self learn any reasonable alternative besides a low torque air injected high rever no pun intended the engine dosent have a header so it dosent have lowen torque unless it’s on a potato chip hull I have seen many under prop just to get on top nice part about being a long time mech got to do at least 1k + sea trials on many different boats powered by the major merc johnrude yami suzukiLast edited by MrG; 08-25-2019 at 07:17 PM.
08-26-2019, 09:44 AM #25000 RPM
- Nov 2009
- hardyville va
- 367
- 7
- 38
- 43
What is the donor motor and the application? Too many questions, not enough info.
08-26-2019, 12:28 PM #35000 RPM
- Aug 2019
- Palmharbor
- 557
- 20
- 58
- 150
Center counsel 21 ft offshorehttps://youtu.be/Hlyxok6634k
Donor is a 2008 225 Etec one bad piston over heat scuffed plastic bag syndrome ,water pomp was fine but showing a rubber transfer in center of impeller this run in the vid was before the jack plate was doing 68 mph you can see the tac holding redline 6700
Twin Outboards, Turn In or Turn Out ?
By Tightrig 12 in forum Technical DiscussionReplies: 13Last Post: 08-18-2018, 08:25 AM -
Mercury Tech: How can I tell what gear ratio I have? Prop turns 1/2 turn per full turn of flywheel
By phaster in forum Technical DiscussionReplies: 3Last Post: 07-20-2010, 06:36 PM -
Turn,Turn Turn Lady Hustler Ejected By www.freezeframevideo.net
By Freeze Frame Video in forum General Boating DiscussionReplies: 1Last Post: 03-26-2010, 07:32 PM -
Turn,Turn,Turn Lady Hustler Ejected video by Freeze Frame
By Freeze Frame Video in forum General Boating DiscussionReplies: 0Last Post: 03-24-2010, 05:04 AM -
a15 analog box turn clockwise or counter clockwise too turn richer
By MENNO in forum Technical DiscussionReplies: 9Last Post: 03-30-2004, 02:52 PM
