Results 1 to 15 of 33
Thread: Vertical Front Cut
08-25-2019, 03:02 PM #1
Vertical Front Cut
Anybody know off hand how much you can cut a vertical front half? I was talking to Chris Carson and he said that the horizontal front has more than double the volume of the vertical and I believe it! I've never had a problem getting RPS's out of vertical 2.0's so I'm just wondering how much it's safe to shave the front...
08-26-2019, 02:50 PM #2
R u stuck on vertical front? , what bout throwin horiz on it?
08-26-2019, 05:28 PM #3
Just curious about how much rpm you have seen from a vertical reed intake? Not trying to a smart guy just looking to learn
08-26-2019, 06:16 PM #4
08-26-2019, 11:34 PM #5Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Like ya don't have the rod that goes to the carbs?????? It is longer on Hozzzz????No other reason not to go Hozzz.....Easy 25 hp......Air box??? I have.....Why stay Vert????
08-27-2019, 07:50 AM #6
Vertical uses a **** ton less fuel. Better torque low rpm.
Azure AZ259, 8.1
08-27-2019, 08:20 AM #7
I have the rod (yes it's longer on a horizontal front), also found an intake in my stash. I have the whole setup. I've got a set of 4 petal cages and TDR reeds ready to go. Just not the direction I'm headed with this one. I may build that one someday but not today...
The horizontal airbox and latch really f*** up a clamshell cowl. This old Varmint has always run great with a stock 1750 on it and that's the way I'm going to keep it!
08-27-2019, 08:36 AM #8Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Ok.... just tezzzin ya......
nitro_rat liked this post
08-30-2019, 09:12 AM #9Member
- Oct 2010
- Easley,sc
- 65
Do you need a clam shell cowl?
08-30-2019, 10:21 AM #10
08-30-2019, 10:26 AM #111973 Viper - sold
1978 Viking - sold
1995 XB02
08-30-2019, 03:31 PM #12
08-30-2019, 03:35 PM #13
I think I am going to pull mine down this winter and put together a 2.0 hydrostream Viper for spring. I also have my Vking what will get a 2.5 by spring. Thanks for the info Nitro!
1973 Viper - sold
1978 Viking - sold
1995 XB02
08-30-2019, 06:26 PM #14Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
I buy a 3/4 inch ball ...greay stone.......start off in the exhust ports.... as stone gets smaller I go to the 3 rd port..... as it gets small enf..... the 2 cross ports...As it gets small ya can finish off the work....at the end it is to a stub.....I use a Cheep BD drill with a 12 inch extenson with a tub to hold at the cutter end. I Have a BP mill so I can do all the rest easy..... but ya still best off with a rat tail on the top of exhust ports....not on the cly wall but where it bends on top...... JMO...I don't D port....the piston hole..... I blend it smooth.....A ball and Rat tail is all ya realy need ... The mill is next step...up.....
08-30-2019, 07:18 PM #15
Wish I had a BP...
2.0 vertical front mystery motor
By dtmeeks in forum Technical DiscussionReplies: 11Last Post: 07-08-2019, 09:05 PM -
Merc vertical front half for 2.0
By Keaten in forum Misc. Parts and AccessoriesReplies: 0Last Post: 12-17-2017, 04:06 PM -
Mercury Tech: Vertical front half woes
By gotboostedvr6 in forum Technical DiscussionReplies: 13Last Post: 10-09-2015, 10:54 AM
