Page 2 of 2 FirstFirst 1 2
Results 16 to 27 of 27
    Jul 2012
    Huntington, Texas
    Quote Originally Posted by idvette View Post
    I was able to thread mine on with my fingers from the inside, then tightened the nuts on the outside of the hull and drew it through until it was tight. No problems, and it isn't coming loose ever.
    Good point, if you can get it snug on the inside you can *usually* do the final tightening from the outside!
  2. #17
    Feb 2017
    Cut it off ,put the nuts on the outside,so much easier to tighten.
  3. #18
    Gravenhurst, Ontario.
    If you don’t have a child of your own in stock I’d suggest borrowing the neighbours.
    $5 and a boat ride when it’s done should cover it.
    DO NOT offer candy as compensation.....that won’t end well.
    please ignore the above suggestions if you drive a white van with no windows.
  4. #19
    Jul 2012
    Huntington, Texas
    Quote Originally Posted by Tomanytoys View Post
    See post #4...
  5. #20
    Jul 2019
    New Jersey
    Thats funny as hell...only because I know exactly what you are talking about, my fat ass used a crows foot and an 18" extension.
  6. #21
    Jun 2009
    central minnesota
    Kinda itchy now arghh[/QUOTE]
    pip always said" iching was just in your head"
  7. Likes Glasstream15 liked this post
  8. #22
    Jun 2018
    Floating around
    The dang thing loosed up a little again too. Crow foot wrenches are one of the few tools I dont yet own. Sorting that out and with some red locktite should be able to get it tight and hopefully it'll last
  9. #23
    Jul 2010
    The Oldest City
    Hole in the deck and a small access plate over it. And if it gets loose again, it's easy to retighten.
    I carry a gun because a cop won't fit in my pocket.
    1987 Glasstream 15V
    1986 Mariner "Tower of Power" 115
  10. #24
    Dec 2011
    Ludington michigan,on the shore
    The wood block that it is mounted to is rotten! The only fix is a four inch hole saw right above the pocket that held the original block and replace it with a good piece of oak glassed in.Iknow it sucks,but been there.I happened to wreck the deck and replaced mine with the deck off.On mine the upper stud was bent down at the factory in order to make clearance for the top deck.
  11. #25
    Jun 2018
    Floating around
    Solid tip indeed and I'll look into it closer over the winter but I dont think its rotten because it doesnt seem to have the best purchase ( its not exactly flat where it should be ) so unless I crank the hell out of it and risk damaging the glass it seems to be still very slightly moveable. My nephew is slender and youthful and I am hoping to recruit him to get up under the deck to help sort it out. I might make some special washers to plumb it up and give it a square fit
  12. #26
    Sep 2017
    Ashland city tn
    I had 1 kept comin loose to and yep the block was bout gone
  13. #27
    Jun 2018
    Floating around
    Hmmm thanks fellas I will surely check it out. Wont be for a while yet, got so much going on for the next few months the boat is dry docked in a heated shop waiting for some attention
  1. Queston for US1, JSRE or Greg Moss. How loose is too loose??
    By DUCKY in forum Technical Discussion
    Last Post: 08-30-2019, 04:43 PM
Spinelli Props
