Results 1 to 7 of 7
Thread: 1982 60 2 cylinder
08-22-2019, 07:22 PM #1Screaming And Flying!
- Miami,Fl
- 6,990
- 128
- 80
- 1269
- 368
1982 60 2 cylinder
Has anyone ever left out the exhaust restricter out and does that cause the water pump to get hot? It looks like it would restrict the exhaust relief. thanks Rick
08-23-2019, 06:58 PM #2Screaming And Flying!
- Miami,Fl
- 6,990
- 128
- 80
- 1269
- 368
Anybody it makes no sense the way the exhaust is restricted.
08-23-2019, 08:02 PM #3
What brand engine ?
08-23-2019, 08:08 PM #4
He's talking about a lemmonrude..... Rick.. what do you mean "exhaust restrictor"? do you mean the adapter between the mid and lower unit? if so, you'll burn up the water pump housing without it
delawarerick thanked for this post
08-23-2019, 08:11 PM #5
08-23-2019, 09:43 PM #65000 RPM
- Aug 2019
- Palmharbor
- 560
- 20
- 58
- 151
That is basically a stinger like a dirt bike ,midsection is the expansion chamber, powerhead has the header if you delete it not only will you melt the water pump @ 1500 rpm an up engine will be a mut till higher rpm
08-24-2019, 08:36 AM #7
It will not melt the waterpump. I have been running without my inner ex housing for 30 years on a v6 crossflow with no water pump damage. You would not believe how much water leaks around the water pump at the drive shaft,just put a lower unit in a barrel and spin it with a drill and you will wonder how any water gets to the power head.
sharpeye Mike liked this post
Sea star pro cylinder on 1975 merc 150 6 cylinder inline
By scott reierson in forum Technical DiscussionReplies: 1Last Post: 07-17-2018, 11:08 AM -
omc 235hp 1982 cylinder
By brussrude in forum Outboard EnginesReplies: 1Last Post: 01-21-2015, 07:15 PM -
OMC Tech: OMC v-6 1982 235 HP PISTON TO CYLINDER CLEARANCE
By brussrude in forum Technical DiscussionReplies: 2Last Post: 12-16-2012, 10:11 AM -
140 johnson 1982, water in cylinder
By Ronny Jetmore in forum Technical DiscussionReplies: 2Last Post: 07-21-2006, 12:01 PM
