Results 1 to 7 of 7
    Jul 2018
    Ma.
    Finding which gear I am in with lower unit off?
    I had to buy a used lower unit for my 1983 Mercury 115 EL(inline 6). Mine was cracked. I was wondering if anyone can tell me how to find forward. The problem is I can find forward, reverse and neutral. I just can’t find all 3 close to each other. I don’t want to mount it then have to take it off to do again.
    Pekin, IL
    You should find FNR within a quarter turn of the shaft. Rotate clockwise from neutral to forward.
    Rock
    Team Junk
    Jul 2018
    Ma.
    I have been trying. What am I doing wrong?
    Dec 2006
    Mt. Laurel, N.J.
    Is the shift shaft stuck? It should rotate.
    Azure AZ259, 8.1
    Jul 2018
    Ma.
    It shifts fine. I’m just having a problem finding forward reverse and neutral together.
    Dec 2006
    Mt. Laurel, N.J.
    Together?
    Azure AZ259, 8.1
    Pekin, IL
    If you can find neutral the switch to forward or reverse is a very small move. Not finding them together may indicate an internal issue.
    Rock
    Team Junk
  1. Whats the best lower unit gear oil?
    By hydro13 in forum Technical Discussion
    Last Post: 11-29-2010, 02:24 PM
  2. Mercury Tech: gear oil out the clean out in the lower unit?
    By ct20sutphen in forum Technical Discussion
    Last Post: 10-08-2008, 06:13 PM
  3. Lower Unit Won't Come Out of Gear
    By Hydrasports205 in forum Technical Discussion
    Last Post: 04-05-2005, 09:44 PM
  4. How to put gear oil in CLE lower unit.
    By Daytona19 in forum Technical Discussion
    Last Post: 07-11-2003, 09:26 AM
