Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
    Aug 2016
    St. Paul
    If I raise my engine up 3 notches (all the way up) my prop centerline will still be 3-3/4" below the pad. I'm gonna do that in the Spring.
    I dug into info on my Stilleto 23p prop. It's long discontinued, but was part of their "Advantage II" lineup. Supposedly they run 1 - 2" stiff and are similar to Laser II props. Once I raise the motor up, maybe that's all I'll need to do. But I might still get a Solas Scorpion prop just to see the difference.
  2. #17
    North Tonawanda, NY
    I ran a Pulse 210 back in the 1990s w/225 Evinrude Vindicator and a 24 pitch Raker- the original Raker rather than the crappy Raker II. No jackplate, motor up 3 holes, and no porpoise at any trim setting or speed. Top end was 72 running light which was fine with me. When I was setting the rig up I tried a Turbo 3 blade in 24 pitch but it slipped like crazy and wouldn't hook up. I also tried an OMC chopper in 27 pitch that I had laying around which wouldn't hook up at all.
    Doug
  3. #18
    Aug 2010
    Barrie, Ontario, Canada
    My 1990 Panther ( Canadian built) from the 18'-6 checkmate molds did not experience the porpoising you are describing. Mind you i had a hydraulic jack plate and replaced all the rotten transom, stringers and floor. It ran 55 mph with a 135 merc, 70 mph with a 175 opti, and 86 with a 225x. Best top end prop was an 28 ET. Best all round prop was a 27 tempest.
    Triad V21 #002 - 15in DBR 300 xs
    19' J-Craft - 175 Opti
    18' Pontoon - 115 CT 4S
  4. #19
    Aug 2016
    St. Paul
    Time for an update. I've had the Pulse 186 out twice this Spring. The first time was to remind myself of everything I previously described. Then I raised the motor 3 notches -- up to the top. Today I drove in the 25 - 40 mph range with a lot less porpoising, but with increased blowouts before getting on plane. In the short term I might lower it a notch. But I think a jackplate may be in order. Still have not bought the Solas Rubex Scorpion S3 (partridge in a pear tree) prop, but I'll report back when I do.
    On a side note: I constantly have to adjust the throttle on this thing, because it just won't stay where I put it. Is the stiffness adjustment in the handle itself, or somewhere on the engine? Mercury Xri 175.
  5. #20
    Sep 2019
    Lake Keowee, SC
    I have a 24P Scorpion, brand new, 10 minutes of run time. I had it listed in the prop section.
  6. #21
    Feb 2005
    seattle
    its going to porpoise until the centerline is less than 2 to even zero. watch out for over heating and/or lack of water pressure. secondly some 4 bladed prop coulD get the transom totaly out of the water and you could lose steering.
  7. Thanks Grant Conklin thanked for this post
  8. #22
    Aug 2016
    St. Paul
    Thanks hsbob. I do have a pressure gauge, and knowing that about the centerline is helpful. I finally bought a 10" manual jack plate yesterday, so I'll be moving the prop centerline higher. I'm looking forward to seeing how that changes things.
    The last time I was out, I was up to 5900 RPM (family of four and a full tank of gas) with my 23p x 14" prop that may or may not run 1-2" stiff. Since the WOT spec is 5500, I know I can go with a stiffer prop, but the Solas / Rubex S3 Scorpion prop I'm considering already runs about 2" stiff. I'm wondering if that has more to do with the fact that it's a 15-1/8" diameter prop than anything else. I'm torn as to whether I should be buying a 23p or 24p S3 Scorpion.
  9. #23
    Sep 2019
    Lake Keowee, SC
    Years ago I had a 216 Wellcraft Eclipse. A 23P Mirage (not a Mirage Plus) and a 23P Stilleto ran about the same speed and rpm. I think the Stilleto was 1 mph slower. A 23P Mirage typically turns 200 rpm more than 23P Mirage Plus.
  1. Checkmate 185 Pulse
    By blue185 in forum General Boating Discussion
    Last Post: 06-29-2018, 08:57 AM
  2. Checkmate Pulse 185
    By bbezok in forum Props, Setup, and Rigging
    Last Post: 04-28-2018, 10:17 PM
  3. Checkmate Pulse 210
    By OrangeCrush in forum Hulls larger than 20'
    Last Post: 05-22-2014, 09:07 AM
  4. 18' checkmate pulse
    By chrisr in forum General Boating Discussion
    Last Post: 12-13-2009, 03:26 PM
  5. Set up for Checkmate 185 Pulse
    By Charles Deckas in forum Props, Setup, and Rigging
    Last Post: 12-22-2002, 03:37 PM
